Results 1 to 18 of 18
Thread: Best way to remove surface rust
    Member resist's Avatar
    Aug 2004
    Newtown
    103 times
    Ok PSB brains trust. What's the best way to remove little specks of surface rust from swingarms, triple clamps etc?
    CLR clear? Sandpaper? A scourer? Piss on it?
    Member Sprint's Avatar
    Dec 2003
    The future
    A Clockwork Orange
    246 times
    Trade in.
    S.
    Member Spike139's Avatar
    Mar 2010
    Behind You!!!!!!
    28 times
    beach riding, let that salty sand just scrub it off.
    butif that doesn't work for you, maybe just use a little rust converter before trying sandpaper, ooo and angle grinder will do it...
    Percute et Percute Velociter
    Member Aufitt's Avatar
    Oct 2011
    Everywhere
    120 times
    8 Post(s)
    Ranex diluted with water.
    Member Daise's Avatar
    Aug 2003
    Pram
    74 times
    6 Post(s)
    What is it on? A ball of alfoil works well.
    Quote Originally Posted by Goof
    You're a liability to have on the back of a bike
    Member Loud's Avatar
    Dec 2009
    South. Just.
    40 times
    Best way? Sand/Bead/Soda blast (depending upon thickness of metal and level of rust) and refinish. Next best? Rub with scourer/sandpaper until all evidence of rust has gone, then refinish. Rust converter will blacken the rust, but leave the rusty texture, but definitely the easiest.
    Member jmoore's Avatar
    Mar 2008
    NOR Meetpoint
    31 times
    Post a pic of how bad it is
    Sent from my GT-I9100
    Quote Originally Posted by polonY
    Don't worry about shitting people off. Unless you ride a ninja 250 or a cbr250rrrrrr
    Member smoothpierre's Avatar
    Oct 2010
    perth
    hyosung
    12 times
    Take a photo of the parts and post it. Then I can recommend a method depending on the surface!
    Aug 2004
    Newtown
    103 times
    Quote Originally Posted by jmoore View Post
    Quote Originally Posted by smoothpierre View Post
    Thanks guys, will post pics later today.
    Member Lord Augastus's Avatar
    Dec 2011
    L1 GSXR-750
    21 times
    1.Sandblast it
    2.Polish it up
    3. Chrome it
    Member duffman's Avatar
    Nov 2004
    8 times
    If its just on the surface, WD40 and a Sctoch-Brite.
    Member agrid's Avatar
    Apr 2008
    264 times
    13 Post(s)
    Ranex, fine steel wool then Autosol.
    Member Geeza's Avatar
    Mar 2009
    THE COUCH!!
    2007 YAMAHA FZ1S + 1973 YAMAHA RD350 Restored
    16 times
    Autosol works well
    I REJECT YOUR REALITY AND SUBSTITUTE MY OWN
    Member Phantom1500's Avatar
    Sep 2011
    Sydney
    SRX250
    9 times
    Old fasion steel wool that is pre soaped, majic on any old chrome etc
    Aug 2004
    Newtown
    103 times
    Here're the pics:
    Member filbert's Avatar
    May 2009
    bunbury
    450 times
    28 Post(s)
    I use stainless steel wool and very light pressure or the balled up alfoil Daise mentioned works well too especially with a bit of wd40 or similar oil, follow up with a decent metal polish such as mothers, autosol etc unless you want to repaint or polish in 5 stages try not to use anything too abrasive.
    Aug 2004
    Newtown
    103 times
    So, steel wool + wd40, then autosol?
    Sounds like a go!
    Thanks all!
    Oct 2010
    perth
    hyosung
    12 times
    Use an extra cut cream polish on the painted surfaces after washing with a soft soapie scourer! On chromed surfaces use a xxxx grade steel wool,(stainless steel is best) Finish with autosol to polish.
    Looking at the surfaces, they wont come up like new but will look heaps better.
