Page 1 of 2 12 LastLast
Results 1 to 20 of 36
Thread: Bike shat it self
    Member axl100's Avatar
    Sep 2008
    wa
    none now
    Bike shat it self
    I was wondering if any one had any ideas.... I started my bike (2002zx636r) it was running then died.. I tried to start it back up but nothing.. Its got me fucked.. It was running for a couple of minutes and now it wont fire up.......
    Member Maxo's Avatar
    771 times
    22 Post(s)
    is there petrol in it?
    Member Gixxerguy's Avatar
    Feb 2009
    Kwinana
    Suzuki Sv650s 08
    5 times
    Have you turned the fuel tap from off to on? I forgot once and my bike only ran for a minute or so.
    Originally Posted by Maxo
    do people around you constantly wear their palm on their face?
    to Butters
    Sep 2005
    34 times
    Kawasaki fuel pumps and relays are bad.
    Maybe also you got some dodgy fuel esp from BP.
    Member AWSE's Avatar
    Jan 2009
    The Scary Door
    R1
    9 times
    I put some 91 in mine from BP and ran like absolute shit. But not straight away, it was a few days later did it start playing up.
    Quote Originally Posted by Bill Hicks View Post
    Today a young man on acid realized that all matter is merely energy condensed to a slow vibration, that we are all one consciousness experiencing itself subjectively, there is no such thing as death, life is only a dream, and we are the imagination of ourselves.
    Heres Tom with the Weather.
    PSB Corporate Sponsor potato's Avatar
    Feb 2007
    STRAIGHTLINE2TEN.
    rattly v-twins-love em
    76 times
    35 Post(s)
    take a plug out and see if its all black and gunged up.
    Sep 2008
    wa
    none now
    there is petrol in it and the fuel tap is on... never had a problem with this bike b4.. i only use 98 vortex.
    Member Psyched's Avatar
    Dec 2006
    SoR
    2009 YZF-R1Y
    As potato says take a plug out and see if it's gummed up, while you have it out (and cleaned if neccasary) earth it and see if you get a spark when you turn the engine over. That will mostly rule out an electrical problem, you should have a strong spark. Though it does sound like a fuel problem.
    Edit: don't hold the plug or lead while you turn the engine over!!! Danger!!!
    Sep 2008
    wa
    none now
    yeah im pretty sure its a sensor or a fuel pump prob...
    Sep 2008
    wa
    none now
    its got me fucked big time...
    771 times
    22 Post(s)
    have you checked for a spark?
    Sep 2008
    wa
    none now
    its got spark!!!! i have no multi meter....
    Member Desmo's Avatar
    761 times
    50 Post(s)
    When you turn the ignition on, can you hear the fuel pump whirring?
    Sep 2008
    wa
    none now
    no i can here the juction box making a noise when you hit the start button..
    Member Cbr1k's Avatar
    Jan 2004
    Your momma's house
    CB1300 & CBR1000F
    37 times
    You sure its not the solenoid engaging from a flat battery?
    Quote Originally Posted by Barfridge View Post
    Please don't tell me you expect an internet argument to end up with somebody changing their mind and admitting the other person is right? That has never happened, not even once.
    Sep 2008
    wa
    none now
    nothing wrong with the battery...
    Member smeghead's Avatar
    Dec 2005
    Forrestfield
    Ducati 916 Bip, ZX6RR for da track
    3 times
    .. if it's got spark then it must be fuel related; both of these are, or can be, affected by a poor battery. When I had a weak battery on my 03 ZX6RR racebike it wouldn't fire as it didn't have enough juice to run the fuel pump & ECU properly & also crank over the bike. Try charging the battery & then get someone to help you bump start it to reduce the battery load.
    Do you know where the fuel filter is? It might be blocked.
    .. and thats Racer # 193 to y'all; my fabulous sponsors (who all do good shit) are: Graeme Fleming IT Consultants, Vision Image, Pacific Safety Wear, Excess Power Equipment, Pro Photo Booth, Canning Vale Travel, Gryphon Garage Doors
    Sep 2008
    wa
    none now
    hey mate there is heap of juice left in the battery..
    Member Mad Mel's Avatar
    Feb 2009
    Where do you live?
    zx14 and a track 10
    Sounds like a fuel pump/relay problem. If it is being pig headed take the plugs out and spray a small amount of petrol in each cylinder, replace the plugs, and let her fire up again. Sometimes this will be enough to get her going. I'd check all relay connections under the seat. Take them apart, give em a shake and spray with wd40, then see how you go.
    Relay switches will fnck you unfortunately.
    Sep 2008
    wa
    none now
    im sick of playing with it now.. too pissed off
