Results 1 to 17 of 17
Thread: Changing grips. Tips?
    Member Rat750's Avatar
    Mar 2008
    Joondalup
    Suzuki GSX - R750 K8
    127 times
    11 Post(s)
    I'm just about to remove the factory grips from the gixxer and replace them with a set of gel grips. Does anyone have any advice on what can be done to make this process as easy as possible? The factory ones are stuck on fairly securely!
    Member The Saint's Avatar
    Dec 2006
    145 times
    1. Cut them off if you don't want them.
    2. Air compressor.
    3. WD-40 with the tube + the blunt end of a wooden skewer.
    I've just thought of something. Suzuki makes a specialised throttle tube with a plastic ridge on it, and OEM Suzuki grips have a channel incorporated into them to accommodate the ridge. If you are keeping the OEM throttle tube and want to fit aftermarket gel grips you might need to cut the ridge off using a dremel tool or razorblade.
    Quote Originally Posted by Melkor View Post
    The Saint is all over the answer like a Saint on a cupcake.
    Member jaseyjase's Avatar
    Mar 2008
    sydney@heart
    OhSevenAhOneTrackie
    Quote Originally Posted by The Saint View Post
    2. Air compressor.
    Assuming you want to keep your OEMs,
    - Air compressor is best, stick it in the tube, blow the air and slide it off.
    - If you dont have one, stick a small screw driver in between the grip and bar, spray some WD-40. Work your way around the whole bar, and it should slide out easily enough.
    Member thro's Avatar
    Jun 2006
    Wellard
    CBR600RR7, 1.5x VJ22 RGV250
    141 times
    7 Post(s)
    +1 for cutting.
    stuff
    Member Cbr1k's Avatar
    Jan 2004
    Your momma's house
    CB1300 & CBR1000F
    37 times
    Cut them off then use KY Lube to put new ones on.
    Quote Originally Posted by Barfridge View Post
    Please don't tell me you expect an internet argument to end up with somebody changing their mind and admitting the other person is right? That has never happened, not even once.
    Dead man walkin' Davey's Avatar
    Nov 2006
    Heathridge
    35 times
    cut them off, ditch your throttle tube and buy a new one for your new grip.. put the grips on by lubing them with contact cement - the contact cement will help you get them on and then make them stick to the bar/tube so they don't spin around
    Mar 2008
    Joondalup
    127 times
    11 Post(s)
    Is that necessary?
    Dec 2006
    145 times
    Cheap as chips from the wreckers Ninjarat. Do an R1 throttle conversion
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    112 times
    i hit the inside of the new tubes with some spray paint which acts as a lube to slide them on and dries to make a weak glue.
    Member PowerStand's Avatar
    Mar 2008
    In The Hills Cutting Up
    CR500
    Run a Phillips screwdriver round the inside of the old to ones to loosen, if you have an air compressor, blast air up the inside and it should glide off.
    Same with fitting, blast air inside the grip. Add hair spray to lube but also to help stick.
    Don’t glue on, makes a mess next time you replace them.
    I don’t ride to get to the end, I ride for that moment
    Hop scotch, skip rope, tunnel ball & football, all the same to me
    If you cant ride it or fuck it, then its not sport
    http://www.perthstreetbikes.com/foru...photos-100704/
    Battlefeild 3 name = 5th_Eye
    Nov 2006
    Heathridge
    35 times
    Quote Originally Posted by ninjarat750 View Post
    Is that necessary?
    depends how much time you want to spend getting all the glue/crap off the old throttle tube so that the new grip a) slides on easy enough and b) has no bumpy bits under it..
    new tubes are a few dollars and im sure the suzuki shop would have some in stock or be able to get them within a day or two.
    Mar 2008
    Joondalup
    127 times
    11 Post(s)
    ok cheers....thanks for the tips
    Member footer's Avatar
    Nov 2006
    north in the police state
    Use Hair spray to put the new ones on. The hair spray when wet is slippery so it makes it easy to put on then dries stricky so will stop them from slipping.
    Member mystery's Avatar
    Aug 2004
    The Pub.
    4 times
    grips for cbr600rr08
    Few tips in there too.
    Member Motz82's Avatar
    Nov 2008
    Waikiki
    2008 SUZUKI GSX-R 1000 LE
    Quote Originally Posted by footer View Post
    i am in agreeance here. cmon guys if we all started on the pedal power and changed our grips on our bmxs' with newies, of course you would grab dads wd-40 nozzle and mums hairspray. in fact i still got some CEDAL brand in the workshop at home.
    hairspray its effective cheap and realtivley easy.
    Member foolishboy's Avatar
    Nov 2006
    Nigeria, Can you help me.........
    Ducati 1098
    3 times
    Another plus 1 for the hairspray, got to be the easiest and cleanest way to pt on new grips.
    Just cut the old ones off.
    In Kazakhstan if you want sugar in your coffee you ask for Kunt
    Member Rhino's Avatar
    Dec 2005
    Yokine
    84 times
    <resurrection>
    Wow, that search thing does work.
    I use gorilla grips sometimes to tie the bike down and it screws up the grips. Pulls them up hard against the switch gear.
    I just used the compressor to help align them again. Awesome tip! Took a couple of seconds and zero effort.
    They were so tight I didn't even need anything to stick em back down again - although an old friend also swears by hair spray.
    Thanks.
