Results 1 to 4 of 4
Thread: compression
    Inactive Member
    Aug 2005
    bayswater
    [attachmentid=1466][attachmentid=1467]hey
    just been checking out a cbr250 (import)
    the compression measurements across the cyclinders are;
    1. 180 PSI
    2. 180 PSI
    3. 155 PSI <----- <_<
    4. 180 PSI
    should i be worried about the low reading on cyclinder 3? or is it within the "range"
    oh and dirt has entered the airbox at some stage.
    this is from a mechanics report.
    any thoughts would be apprciated (related to this post)
    cheers
    Member shrike's Avatar
    Jul 2005
    San Francisco
    yer mom
    I&#39;d be worried, but then I&#39;m anal.
    Do a second test, to be sure. I remember taking my car in to get a compression check and it came back with one low reading. Took it to my regular mechanic who checked it and it came back normal and even across the board. He said it could&#39;ve been a bit of carbon blocking a valve from fully sealing or something.
    25 PSI isn&#39;t much in the scheme of things, but if it starts getting to 30... 40... 50... etc, well...
    Quote Originally Posted by http://www.textsfromlastnight.com
    (626): I'm trying this new thing, it's called standards
    Member Jonchilds's Avatar
    Oct 2005
    Looking for a Z1300
    If the bike is running fine, and smoothly - then I&#39;d not be too worried. If you&#39;re getting it missfire regularly, then it&#39;d be something to get checked out.
    Most you&#39;re going to get from a 15% decompression in one cylinder is a slight loss of performance, and either some blow-by, or valve leakage. Neither is particularly urgent to fix, and can usually wait until the next time the head is off (atleast that&#39;s what I do with my cars).
    Inactive Member
    Nov 2005
    id take all the advise from above and do a second test but when i did a compression test on my car it was out by less than that and i had to fet the head skmmed off and a new seal kit to stop it from leaking a bit which aint a major problem it aint something u want but ya can survive with it. i dont know much bout bike engines im not sure if there the same kinda things as cars im guessing not .
    Dont Fight with utes while on your bike it hurts
