Results 1 to 11 of 11
Thread: Custom Tank Pads/Decals
    Member NikyNoo's Avatar
    Sep 2007
    Mooloolaba QLD
    07 Honda CBR1000RR
    Is there anyone in Perth that can be recommended to do custom tank pads?
    Ta
    Member Captain Starfish's Avatar
    SOR, near the airport
    113 times
    If you can't find what you're after, have a look at the places online that do custom mouse pads using wetsuit rubber. You'll have to use contact adhesive to attach them etc, but it should be fine.
    If you have no luck there, even, I have access to a thermal transfer flat press which will take your design and (probably) get it onto an offcut of wetsuit rubber.
    These are kind of last resorts though - if someone actually does this stuff as a business go that way first!
    Member Machast's Avatar
    Sep 2005
    The Ninth Realm
    1. Buy clear tank pad
    2. print design on paper with adhesive backing
    3. apply clear tank pad over design
    4. trim around pad with a sharp knife
    5. use paper's adhesive to adhere to tank
    FIFO. Living the Pilbara dream.
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    25 times
    BlackFZR got some made over the net. will see if he notices this post, probably will, if not PM him
    contact adhesive contains solvents, it WILL eat your paint
    Inactive Member Foofie Foofie's Avatar
    Mar 2005
    Shar'n a room with Snoop Dogg in m'fukin Compton.
    I make them .... clear them up in a special resin thats UV sensitive so it goes off and makes it a thick "3D" sticker.
    Taz
    Taz is online now
    Member Taz's Avatar
    mid south near some water
    tigerblade
    go to foofie
    here is a pic of the man and a little project he whipped up
    A site all parents should check regulary
    http://www.mako.org.au/temp_a.html
    Mar 2005
    Thanks Taz, that bike rocks !.
    Pic of my SP-2 pad ...
    Member taDere's Avatar
    Sep 2006
    subiaco
    gsxR 600
    foofie, you would make and sell some ?
    assuming that you do, what details would you need and what would be the pricing?
    BTW, that looks wicked !!
    Jesus' Little Bitch Satan1's Avatar
    Jul 2007
    9 times
    Quote Originally Posted by Foofie Foofie View Post
    That looks neat!
    New Member
    Nov 2009
    custom tank pads does any know any web sites?
