Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: What revs to u cruise at?
    Member duffman's Avatar
    Nov 2004
    8 times
    just curious about what RPM people (mainly with big bores) sit on while just casually cruising around.
    i aim for about 3500
    Inactive Member
    Guys, for a good time PM Me
    the lowest possable rev with out making the bike struggle
    but i'm a bitch
    theres a guy at work called LEN who sits on 8500 rpm
    all the time
    Inactive Member mudokan's Avatar
    Apr 2005
    but i'm a bitch
    all the time
    [snapback]145138[/snapback]
    haha thats like normal for us 2fiddy cibbys
    necessity is the mother of innovation
    Inactive Member
    May 2004
    Biaggibup
    Depends on the speed...mine is 10,500 ish at 110km/h in 6th.
    Russ
    Fat kids always win at see-saw
    Member Mattis's Avatar
    Perth, NOR
    98 R1 - Blue Goodness
    My blade does 100km/h at about 4050rpm-ish, alot of my commuting is done on the freeway so yeh thats the average cruise speed for me.
    I have to get rid of my flat spot at 4200-4800rpm though, really pissing me off atm
    Member rz350's Avatar
    Jul 2004
    Butler
    ZX9R
    [snapback]145152[/snapback]
    Ditto for me, between 4000 - 4500
    gohan
    Guest
    mine is 14000 to 15500 RPM nothing less
    Member Courts's Avatar
    Canning River
    09 K9 BUSA
    3 times
    I sit on about 4600rpm in sixth at 110kmh.
    Nov 2004
    8 times
    what year is that?
    mines sits on about 3800 at 100km/h
    a real change from the CB which would sit on about 7500 at 100, and you would use 5th gear for any speed between 50 and 120
    i might start cruising at closer to 4000 with gear shifts at 4500. it just sounds too nice to try and keep her quiet. also, once the revs drop below 3000 she gets a little sluggish under acceleration
    cheers
    gpx_gal
    Guest
    Depends.. usually 4,000-4,500 if im just pottering along (very rare).
    If I want a little power to play with 5,000-5,500 better than shifting down and then gassing it.
    Inactive Member Churchy's Avatar
    Jun 2003
    Rev Limmiter
    ...and on the seventh day God said "Let there be light!", and Chuck Norris said "say please!"
    Inactive Member ONYERBIKE's Avatar
    Apr 2005
    ummm doesn't the ideal speed cpme into play somewhere?
    I have mine idling around 1300 rpm (I think it's meant to be a little more), screams like a bitch in 2nd at 14
    Will have to look on way home, think I remember seeing it at around 4000 at hundred in 6th just cruising.
    If you've put yourself in a position where someone has to see you in order for you to be safe -- to see you, and to give a fuck -- you've already blown it." -- Neal Stephenson,
    Member seandre's Avatar
    Jun 2005
    L0 GSX-R 1000
    54 times
    about 3500 at 100km/h.
    i try to put it along between 3500 and 4000 most of the time. Grunt is on tap from 3000 with the bandit.
    xphread
    Guest
    GSX750F was 5,000 for 110.
    didnt get enough play time with the ZXR before it was nicked... but speed seemed higher for same sound, so I guess a bit lower in the revs department for the ZXR.
    I&#39;ll let you know in a few weeks when shes back on the road. <_<
    Member spawn's Avatar
    Apr 2004
    Rivervale
    04 R1
    [snapback]145191[/snapback]
    Spot On Same Here!
    If life is a journey to death, then i want to just barely make it... skidding in sideways out of gas with smoke rolling from the motor on two bald tires, still drunk from last night and still owing everyone money!!!
    Inactive Member Foofie Foofie's Avatar
    Mar 2005
    Shar'n a room with Snoop Dogg in m'fukin Compton.
    Any rpm is fine, just make sure its not constant . I ride with different rpm depending on weather , to make the waterpump work in its effeciency (SP&#39;s run warm due to side mounted rads at lower speed in summer) ,and depending if i want to cool the oil before i shut the motor down.
    Inactive Member devilsaltarboy's Avatar
    Sep 2004
    Bassendean WA
    I normally cruise anywhere between 6000rpm (3rd gear at 60) to 7.5k for 80kmph (3rd gear still) sometimes knock it into 4th gear just to change the revs a bit. Not sure what your meant to rev at it just seems the most comfortable and gives u enough power to get out of trouble.
    Member Infusi0n's Avatar
    WA
    VTR1000F
    I find myself putting around 2.5-3k on the VTR at 60km/h in 4th, at 110 its 3k in 6th Will still pull away from either of those revs (loves the vtwin) but like SAF said, the VTR&#39;s side mount radiators can make the bike get mighty warm at below 60km/h
    Perth, NOR
    didnt get enough play time with the ZXR before it was nicked... * but speed seemed higher for same sound, so I guess a bit lower in the revs department for the ZXR.
    I&#39;ll let you know in a few weeks when shes back on the road.* <_<
    [snapback]145209[/snapback]
    From memory it was about the same as the blade, that is ~4000rpm to sit at 100km/h, she does good fuel economy as well.
    Member dr00's Avatar
    Oct 2004
    29 times
    bout 5-5.5k for pottering around at 60-70.
    Quote Originally Posted by Friedrich Hayek
    "The curious task of economics is to demonstrate to men how little they really know about what they imagine they can design."
