Results 1 to 14 of 14
Thread: Why dual throttle cables?
    Member Uncle Flash's Avatar
    Nov 2008
    Way Out West
    Awesome Italian Scooter & Awesome Italian Motorcycle & Awesome Italian Bicycle
    17 times
    Can anyone tell me why the Keihin FCR carbs on my Ducati 900SS require the dual, push-pull cable system?
    Please, call me Flash...
    Member agrid's Avatar
    Apr 2008
    260 times
    13 Post(s)
    in case the spring breaks
    Nov 2008
    Way Out West
    17 times
    Flatslides are probably better than some carbs mounted on the side of the engine as the heavy slide mechanism could probably close itself off if the spring broke. If it is as simple as a back up for the spring, why don't all carbs use the system?
    Member BERT's Avatar
    Nov 2005
    Dianella
    Ducati Paul Smart 1000, Kawasaki KR1S,
    62 times
    My Guess
    Pull - pull cables are used so a lighter return spring can be utilised and you get a positive action in both directions.
    A bit like a desmo throttle cable I suppose.
    Bert
    Hunter S. Thompson
    Member Magilla's Avatar
    Jul 2008
    Alice Springs, NT
    CABS '09 CBR600RR
    75 times
    My CBR600RR has dual cables as well.
    -Magilla
    Putting a fresh install of Windows on the internet is like giving a nymphomaniac a job at an STD clinic and then slipping viagra into their coffee. It may seem like a good idea at the time, but trust me, it isn't.
    R class test passed - Eligible to shadow R-E 26/05/13, R 26/05/14
    Apr 2008
    260 times
    13 Post(s)
    you answered your own question If the spring breaks on the freeway the slides will 'probably' close... that or you'll keep going till you run out of gas or hit something like a car or preferably the kill switch. I assumed they were a design standard that came in yers ago.
    Member Sumfun4me's Avatar
    Mar 2008
    Southern River
    Ducati 1198S Corse
    3 times
    Bert's explanation sounds about right to me. It's probably got something to do with limiting the stress on your wrist.
    __________________________________________
    To err is human.
    To arr is pirate.
    Check out my 1198s Corse SE in the garage: Desmosedici Ohlins forks, magnesium wheels, Ohlins TTX rear shock, Kyle racing link, alloy subframe, carbon fairing stay, ceramic coated Termi full systen, PCV, lots of carbon & titanium.
    MIK
    MIK is offline
    Member MIK's Avatar
    May 2008
    kalamunda
    Yamaha FZ1S,Norton Commando, WR450F, YZ250
    I pretty sure it a requirement for new road bikes to have this maybe not here but the US. Its a safety thing, although it also increases responsiveness.
    CAMS also a requirement for carby'd cars to run two.
    Member MattyA's Avatar
    Jul 2008
    Cuttin Ya Grass With Ma Bike
    FZ6n & '78' TY175 Resto
    7 times
    4 strokes give you power where you want it. 2 strokes are more on off power .
    Thats what i figured for dirt bikes anyway
    Member ranmar850's Avatar
    Jul 2007
    Kalbarri
    ZRX1200R, X1 White Lightning, 06 FJR 1300, Norton Commando
    32 times
    You may find it has been a legislative requirement for quite some time, in the interests of safety.
    " Lightly Seared On The Reality Grill"
    Member Nudge's Avatar
    Mar 2009
    Forrestfield
    Suzuki Bandit 600S, VFR750, GPX750R, TS250X, DR250R
    7 times
    Quote Originally Posted by MattyA View Post
    I thought I might have had an answer until I read this. What was the question again?
    Member gengo's Avatar
    Apr 2009
    Sydney
    zx6r
    its the decellaration cable and accelaration cable my new klx250 has it also and thats what it is stated as in manual, sort of like a safety to ensure throttle dont jam and go flat out in case of emergency
    Member PaulMac's Avatar
    Nov 2008
    Carvin' the trails
    ZX9R, CR125 02, KTM125EXC 09
    I have read that under some engine conditions (such as a backfire back up the inlet side) that the spring alone will not close the throttle slides down so the push cable is a safety thing to ensure that throttle closes when you expect it to and under all conditions. 2 strokes don't generally have a push/pull throttle system as they don't usually have problems that the 4 strokes do. It'd also why 4 strokes sometimes have backfire screens in front of the air filter - to stop it catching on fire in the event a a backfire into the airbox. Fun hey!
    Paul
    Stuff the four strokes. I'm waiting for the two stroke renaissance.
    New Member Nero Diablo's Avatar
    Oct 2004
    Out there
    21 times
    Think it might have more to do with CV carbs than flatslide's, which you ducati has OEM. The flatslides are probally set up to run the OEM system for ease of installation, My goose runs twin cables but they are both pull, one fo each carb this was the same arrangment with delorto's bike is a mids 90's design same as the ducati so it would have had to meet the same legislation.
