Results 1 to 18 of 18
Thread: Anyone know how to replace a timing belt in an 06 holden viva?
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    This thing is a fucking prick. Trying to get the belt off but I can't get the belt loosened. The only manual I can find is for a slightly different motor, which has one less pulley. It says to loosen the water pump retaining bolts then move the water pump to do it, but the extra pulley I have is in the way? I have NFI.
    Member Jedi's Avatar
    May 2007
    Toodyay
    None
    Nearly a year and you haven't even taken her belt off? Haha Bunyack owes me $20.
    Sorry bro I got nothin'
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    well to be fair, one belt is off. Just not the difficult one. Its really, really shitting me.
    Douche
    Aug 2008
    Marangaroo
    08 CBR600RR
    51 times
    11 Post(s)
    1 Thread(s)
    Angle grinder? Once the belts off you will have more room to work, and I've found belts are always easier to get on than off.
    Member karen's Avatar
    Jun 2007
    Belmont
    126 times
    34 Post(s)
    When we had to do one, we went to the Alexander library and photocopied what we needed from the manual there.
    Otherwise, I have nothing either.
    Don't break anything!
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    Figured it out, but I did break a torx socket Need to replace it then do it.
    Member Mr_Mike's Avatar
    Nov 2008
    banging ho's and hittin fat blunts
    Ninja 250 with carbon 2bros pipe
    2079 times
    115 Post(s)
    if ur doing a timing belt and ur strugglin to remove a fan/ac/waterpump belt i'd suggest takin car to a mechanic.
    "Road racing, you get it wrong just a little bit and you're dead....... I like that" - Guy Martin
    B19 Oakford V.B.F.S
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    The waterpump runs off the timing belt. The confusion was caused because the manual I had was for a 1.6, and the newer 1.8 has an extra tensioner pulley, but I broke the torx bolt trying to get it off.
    New Member
    May 2010
    wyee nsw
    vf 750
    can you tell me
    I have a 2006 viva
    How did you go with your? you were complaining about the belt being hard to remove, was that the fan belt or the timing belt? I also downloaded a "users Manual" that shows 4 bolts to remove the crank pulley, when I look at mine, I have one 17mm bolt. Didi yours have this and was it hard to get off?
    I can ring if you provide a number to chat.
    Thanx
    Member Viper's Avatar
    Mar 2007
    Ellenbrook
    06 Ninja ZX-6R 636
    147 times
    33 Post(s)
    who buys a viva ffs????
    New Member
    May 2010
    wyee nsw
    vf 750
    Quote Originally Posted by Semi View Post
    so did your have 4 bolts or one on the crankshaft pulley?
    Member CBRay's Avatar
    Mar 2010
    Ellenbrook
    2011 Z1000, 2006 CRF450R
    27 times
    Yeh barinas have the 1.6 and there tensioned off the water pump, but vivas have the 1.6 and they've got the tensioner pulley.
    yeh ive broken a T40 on one as well, those bolts are fucking tight! i usually take a hammer and chisel to the bolt to undo it.
    btw im a mechanic and i work at a holden dealer so ive done quite a few lol
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    Haha that makes me feel pretty good about it then mate. Those torx screws are fucked to try and remove. The second one I twisted about 30 degrees (one end of the bit was twisted). I have no fucking idea why you would use a torx bolt on it, just seems like a stupid bolt to use that tight.
    SOR, near the airport
    3030 times
    152 Post(s)
    10 Thread(s)
    Remember, semi - lefty loosy, righty tighty
    Buy my camera, an awesome tank of 1Ds awesomeness! Details here
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    I was undoing it the right way fishy. Just on ridiculously tight.
    Member Cbr Junkie's Avatar
    Oct 2009
    Glen Forrest
    06 Cbr600rr, 85 Cr80
    Your tork bits arnt those tamperproof ones with the hollow middle are they? those ones break really easy.
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    78 times
    11 Post(s)
    Yeah, i think it may have been. It was a quality one too from a blue point set.
    Mar 2010
    Ellenbrook
    27 times
    Yea i no i swear everytime i see a torx bit on something tight, it just shits me, seriously wat is wrong with a normal hex bolt???
