13-07-2008, 04:25 PM
#1 (permalink)
91 Honda CBR1000F, 125 High Quality Chinese Stunt Bike
Carb Guages
I'm thinking that I need to be able to balance carbs on both bikes - XJ600 and CBR1000. I have no idea what guages are suitable - can anyone point me in the right direction?
13-07-2008, 04:29 PM
#2 (permalink)
K6 GSXR750
carbtech i think theyre called, work well
14-07-2008, 06:54 AM
#3 (permalink)
15-07-2008, 03:00 PM
#4 (permalink)
K6 GSXR750
he said 'be able to balance carbs on both bikes'
not
'pay someone to balance carbs on both bikes'
15-07-2008, 03:04 PM
#5 (permalink)
You can make your own with clear pvc tube, micro-irrigation fittings and a length of board.
Basically, you need a board with four or two hoses (depends on # carbs) running vertically into a "manifold" made of T-pieces and elbows at the bottom. About a metre high. Tops of the hoses go to the carbs via straight connectors (which put constrictions in the tube). Fill it to about 700mm high with oil.
Connect to the vacuum ports and off you go - get them level!
__________________
15-07-2008, 03:08 PM
#6 (permalink)
07 VFR 800
....so basically a manometer, right?
__________________
15-07-2008, 03:09 PM
#7 (permalink)
2001 Ducati 748R
I thought a manometer was a measure of how many chicks you'd nailed?
__________________
15-07-2008, 03:11 PM
#8 (permalink)
K6 GSXR750
oh. I thought it was a ruler?
15-07-2008, 06:35 PM
#9 (permalink)
CB1300 & CBR1000F
Morgan Carbtune, is piss easy to use. Works well on my Cbr thou
__________________
You can confiscate my bike when you pry it from my dead hands.
15-07-2008, 06:38 PM
#10 (permalink)
+1 for Carbtune Pro.
15-07-2008, 06:51 PM
#11 (permalink)
yep, four input differential manometer
__________________
15-07-2008, 07:17 PM
#12 (permalink)
07 VFR 800
Figured thats what you were talking about
__________________
15-07-2008, 07:24 PM
#13 (permalink)
The other alternative is a couple of vacum gauges or those stupid power economy gauges they used to fit to Comodores and Falcons in the 80's.
24-07-2008, 06:59 PM
#14 (permalink)
hehe! Look what came in the mail today.....
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Sponsors |
