Results 1 to 13 of 13
Thread: carb problem on my gs
    Member smokeymatt's Avatar
    Oct 2007
    Beechboro
    GSXR 750. GS1000st
    my carbs on my gs1000 are running hell rich, fuel consumption is out the window and my plugs keep fouling, mainly when i am off the idol curcuit. the carbs are clean and properly set up. Any ideas?
    I'm Living the dream.
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    117 times
    worn needles/needle jets?
    Apr 2009
    Walliston
    Pumba
    401 times
    11 Post(s)
    Has it always been like that, or has the problem just developed.
    CBT
    CBT is offline
    Member CBT's Avatar
    Oct 2009
    Ascot WA
    Bimota YB8, GSX11 resto, GS1000S and T250 Hustler projects
    5 times
    I have a factory manual for the GS1000S's if you want/need some base line info.
    Oct 2007
    Beechboro
    GSXR 750. GS1000st
    the bike has never run properly and the process of nailing down the issue has been interestion, but i think what it comes down to now is that the main jet is too big.
    CBT
    CBT is offline
    Member CBT's Avatar
    Oct 2009
    Ascot WA
    5 times
    Matt - depending on the year of your GS the carbs vary in their spec and set up, just a point to consider if you are buying bits and pieces.
    79 model - flat seat, solid discs, bigger instruments wth clock etc = 28mm carbs
    80 model - stepped seat, vented discs, smaller instrument cluster = 30mm carbs
    New Member
    Oct 2011
    Canning vale
    Suzuki Katana
    Fuel tap can cause issues if the vacuum diaphram is split it can suck fuel through vac line causing rough running and fuel smoke running rich etc
    Member agrid's Avatar
    Apr 2008
    265 times
    13 Post(s)
    All plugs fouling?
    Member Phantom1500's Avatar
    Sep 2011
    Sydney
    SRX250
    9 times
    Float heights correctly adjusted?
    Balance prob, vacuum balance all carbs.
    Member HK31A's Avatar
    Jan 2010
    Perth WA
    Quote Originally Posted by smokeymatt View Post
    is that the billy idol circuit
    Member Para045's Avatar
    City of Wanneroo
    109 times
    Quote Originally Posted by HK31A View Post
    Nah the American Idol
    Sep 2005
    34 times
    GS1000 with standard jetting etc needs stock standard airfilter set up!
    Having different airfilters on the carbs throws out the fuel-air mixture, normally way to rich due to less air resistance and non scavenger effect!
    Oct 2007
    Beechboro
    GSXR 750. GS1000st
    the main jets shoule be 97.5 and they are 110, have got a set and will fit them soon and let you know. The bike has 30 mm smooth bore carbs and i am hoping it will failey move.
    thanks for the tips guys, Jamathi, nice to hear your still around, how about a ride on you rg?
