Results 1 to 14 of 14
Thread: Chain vs belt vs shaft
    Member NanoBear's Avatar
    Jan 2007
    Fremantle
    Suzuki Intruder VL250
    22 times
    Just out of curiosity really...
    My dad's cruiser is shaft drive, the bike i want (also cruiser) is belt drive, while to the best of my knowledge, sports bikes are all chain. Is there a mechanical/technical reason why sports bikes are all chain, or are there some that aren't? Only thing I can think of is a power/strength issue, but surely a 2.3L rocket III(shaft) or a 2.0L vulcan 2000 (belt) have more power than than the small sports bikes. The way I understand it, the chains require somewhat more maintenance than the other systems.
    Member Captain Starfish's Avatar
    SOR, near the airport
    100 times
    Dunno about belts.
    There's a reason all the race bikes use chain, it's because chain is the most efficient power transfer mechanism from engine to wheel.
    But, chains get full of rubbish and need lubrication and maintenance. So from that point of view, the shafts are great.
    Having had both, I'd not really think about it much. If you have enough power through a shaft drive, you score - much lower maintenance (although the final drive, or equivalent of a diff, tends to wear out eventually and they're a bit more expensive than a chain and sprockets).
    If you have a chain, the maintenance isn't much - lube it with proper sticky shit every two or three tank fills. Occasionally try to pull the chain away from the back of the wheel sprocket - if it lifts completely off the teeth, time to replace.
    Not too much either way, IMO.
    Member thro's Avatar
    Jun 2006
    Ashfield
    CBR600RR7, 1.5x VJ22 RGV250
    7 times
    Shaft = heavy
    I think a belt would be more prone to slipping.
    Chain = dirty, cheap, but does the job if you maintain it.
    edit:
    22,000km on my chain so far. its still good.
    If you spend 5 minutes every 2 weeks lubing it and clean it every now and again, its no big deal.
    stuff
    Member MADOGA's Avatar
    Apr 2007
    If your looking at cruisers belts are probably better than shaft, with a shaft you can get shaft lash, some bikes get this worse than others, beyond that probably not much difference between the 2 other than visual.
    Belts are great keeps the bike a lot cleaner,wont slip unless its faulty or the engines has had some serious work done to it, and look nicer from a biased point of view.
    Member BigTim's Avatar
    Mar 2006
    Tiller
    Quote Originally Posted by Captain Starfish View Post
    Or you could just tighten it?
    FTP
    Member D'Artagnan's Avatar
    Aug 2006
    Somewhere between Perth and Cairns
    Benelli TnT CR 1130
    16 times
    Belts would be the best compromise IMHO. Shafts also (though they're getting much better) have the torque issue. This is because the mass of the spinning shaft in one direction will mean the bike will resist tipping one way, but assist the other. But really, nowadays there's not much there. Although it may explain why FJSteve likes only going left!
    Belts are lower maintenance than chains. Probably the reason BMW chose belts for their F series.
    Chains need to be lubricated often. Failure to do this will mean new chain and sprockets, and at worst, you can damage bearings from what I've been told.
    Check here
    D'Art
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    25 times
    Shaft drive would also have power loses..
    Fj Steve prefers turning left because thats the side he falls off the bike, when he is tired
    Member Ferris's Avatar
    May 2004
    BNE
    09 Busa
    3 times
    Belt drive here: They snap under duress, like wheelies. No maintenance, no lubrication, no tightening needed. They don't slip. (they're not like a fan belt, they're toothed, and have sprockets to match.) Also, super quiet.
    But yeah, only downside, they can snap. It's rare, and I've only ever snapped one, but that's 1 more than any chain.
    Work Buy Consume Die
    Member Hostilemonk's Avatar
    The Hills
    R6 Zimmer frame #16
    ^^WTS
    Shaft - less efficient than others, less power to rear wheel, great for long distance as no chain oiling or maintenance, no adjustment, clean, modern machines don't have that much jacking from the shaft. cheap to run (nothing to replace eg. sprockets). I prefer shaft on a road bike
    Belt - more efficient than shaft, no maintenance, can be problematical on hi performance machines, as belt is comparatively wide needs wider sprockets so not good on sports machines, can snap - until new materials become available will be limited in application IMO. BUT can be a total pain to replace as there is no joining link - have to take the bike apart on some models e.g. some Harleys - how would you fit a belt to modern sports bike unless it had single sided swing arm?
    Chain - most efficient, needs constant oiling (use an oiler like scott for long distance), needs regular adjustment, costly, dirty, great for short rides and racing, not worth it for long distance riding IMO.
    For road riding, unless you want the last .005 HP and a shaft is available in the class you want, then shaft is better IMO.
    look at the 'top 5 or 6' sport tourers = shaft drive.
    Supported and kept fit by
    Aug 2006
    Benelli TnT CR 1130
    16 times
    Quote Originally Posted by Hostilemonk View Post
    Look at the top selling Sports Tourer of recent years and it has a chain, but point taken :p
    All good points BTW.
    Feb 2008
    Sportsbike with a belt drive ....... come look at my Buell XBSTT
    100 times
    Quote Originally Posted by SYLO View Post
    Oh. I geddit. Hahahahahaha
    May 2004
    BNE
    09 Busa
    3 times
    Hey, fuck you Starfish.
    Member rossguzzi's Avatar
    Jul 2007
    Chains popular for sportsbikes because for racing its easy to change ratios. Very difficult for shaft bikes.
    Belts ok, but watch you dont get a stone inbetween belt and pully!
