Perth Street Bikes
Go Back   Perth Street Bikes > MOTORCYCLE TOPICS > Mods, Being Technamikle & Product Reviews
Mods, Being Technamikle & Product Reviews Mods, general bike mechanical discussion & product reviews
Reply
LinkBack Thread Tools
Old 11-07-2008, 11:40 PM   #1 (permalink)
07 R6.....
BlackFZR's Avatar
Customising your Bike - Fuel Management Systems
Customizing your bike…..
Bike customization is about making your bike reflect you as an individual. This can be done by simple bolt-on replacement modifications, or the more advanced custom paint-scheme and custom stickers, right the way through to major frame and hardware modifications such as street-fighters and extended swing-arms etc. This morning I want to introduce and identify the availability one simple modification that will effect how you interact with the bike, as well as make your bike that bit more like your own. This is the beginning of a series of threads that will identify other bolt-on option that will personalize your bike.....
Fuel Management Systems.
Now once you have chosen that Exhaust/System that helps you add that element of sound that you want with the look you have, it is a good idea to actually re-tune your bike to ensure that is not running lean, and potentially harming your engine.
Briefly, replacement exhausts/systems improve flow through the engine, by scavenging exhaust gases quicker, and pulling more air into the cylinders prior to ignition. If you don't add additional fuel, your bike will run lean (more air = higher air/fuel ratio, which is bad in some cases).
To counter this, there is a series of simple after market plug-in systems that can help you with fuel management, as well as the more expensive advanced Fuel Management packages which will allow you to customize your engine management to a higher degree, and with additional features.
Simple Plug and Play Systems:
The following systems will plug into your wiring harness and allow you a simple level of fuel management for your bikes. They don't require any additional plug-in to a computer to be able to tune your bike, they are just a simple plug-in and tune from the side of the road via on the module buttons and flashing LED's.
Dobeck Performance – DFO Gen 3
Cobra – FI2000R
Two Brothers Racing – Juicebox
Each of these produce Fuel Management Systems (FMS) specific for a bike model, that are simply plug and play, requiring no splitting or soldering of wires.
Advanced Plug and Play Systems
The Dynojet PowerCommander (PCIII)is an advanced system, which has the option to do some coarse adjustment through on the bike tunability, but also has fine adjustment via connecting to your computer via USB, and changing the fuel map for 250 rpm increments. Additional accessories can be added to the PCIII that will allow you to effect ignition timing, as well as complete some basic datalogging functions.
The Tuneboy is a system which has been developed purely for the Triumph, Benneli, KTM, Aprilia, Buell & MZ range of motorcycles. It is similar in that it can be used as a simple plug and play system similar to the others mentioned to date, but as well as allowing fuel management, it also allows you to change rev-limits, iginition timings, air-fuel targets etc, and all wihout having to stay plugged into the bike. This management needs to be completed via a PC, but rather than having the Tuneboy left on the computer, it can be used to actually flash the stock ECU to reprogram it to the new settings.
The Bazzazz Performance Z-Fi is slightly more advanced than the Dynojet, as there is no "coarse" adjustment feature available on the unit itself, all tuning has to be done via a USB connection with a PC. This is no different to what the Dynojet PCIII can do. However the advantage of the Bazzazz system is the extra's that can be purchased to fit in with it. You can also purchase an Air-Fuel mapping kit that will allow the Bazzazz Performance system to search and set your fueling to a specific Air-Fuel ratio based on a closed loop tuning set-up, as well as log and create a map that can become a permenant tune. In addition there is a Traction Control and a Quick Shift Kit that can also be added to the system to allow you current cutting edge racing technology at your fingertips.
The Motty Electronics AFR Tuner is a step up from the Bazzazz Performance system. Rather than having the closed loop tuning system as an optional extra, it is supplied as part of the main unit. Again this is a PC only tuning system, and the AFR Tuner also has a data logging component which logs Air-fuel Ration, throttle position, rpm, gear (if your bike has a sensor), coolant temperature, and a single user defined sensor.
Summary
Of all the options that have been mentioned to date, these are listed from minimum to maximum complexity/features, and are only really required if you start to play with either engine internals, or your exhaust. A lot of these systems are actually for Race Use only, so use them at your own peril.
More advanced entire engine management systems will be looked at in the future......
Simmo
__________________
Sponsored By: Dynapumps, MOTUL, Kennards Hire - Cannington, Mobile Motorcycle Medic, Motorsportpics.net , Loadstar Trailers.
BlackFZR is offline   Reply With Quote
Old 13-07-2008, 07:04 AM   #2 (permalink)
Nero Diablo's Avatar
Replacement fully programmable ECU for older webber marrelli products Jefferies MyECU
Chips for older ECU's replacement for newer ECU's of the webber Marelli variety. Fuel Injected Motorcycles - home of the UltiMap U59 Engine ECU for late model Ducatis
www.showangomotorcycles.com.au Aust distrubtors for Kilein racing carbs.
Nero Diablo is offline   Reply With Quote
Old 30-09-2008, 05:43 PM   #3 (permalink)
ZX9R
Has anyone used an Autronics unit with a turbo with any success?????
I am looking at this option and wondered if there was any options either way.
ZX9R is offline   Reply With Quote
Old 09-10-2008, 09:36 AM   #4 (permalink)
I doubt that any of these would work as most bikes?? use TPS for their load values. Running a turbo you would need MAP sensing for load.
Best person might be to try Glenn Campbell on 041 882 2444.. He sells and tunes computers. I believe he has tuned turbo bikes before.
datsikk is offline   Reply With Quote
Old 09-10-2008, 10:30 AM   #5 (permalink)
They use Autronics on cars with turbos.
CT90 is offline   Reply With Quote
Old 14-10-2008, 04:44 PM   #6 (permalink)
ZX9R
Thanks I am a little way of yet but will give him a call when the time gets closer
Old Yesterday, 10:43 AM   #7 (permalink)
1986 fzr 400
madmike's Avatar
wat about bikes with carbys ???? not fuel injected
madmike is offline   Reply With Quote
Old Yesterday, 10:47 AM   #8 (permalink)
2001 Ducati 748R
Desmogod's Avatar
Why would you need a fuel management system on carbies?
Rejet mate.
Desmogod is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
» Sponsors
» Current Poll
Is it right for Govt to bail out businesses for stuffing up
Yeah we need a safety net - 21.33%
16 Votes
No let them jump from their skyscraper offices - 58.67%
44 Votes
I don't care it's in the US they do stupid things - 20.00%
15 Votes
Total Votes: 75
Advertise on PSB
