Results 1 to 20 of 20
Thread: Do track bikes need a radiator fan?
    Jul 2011
    As the title says, do track bikes need a radiator fan? Just wondering if i can ditch it...
    Member Thirsty's Avatar
    Jan 2010
    In the Middle
    The Busa's Brother From Another Mother!!!!
    52 times
    7 Post(s)
    Im not sure, but maybe if you were entering Superstock you probably have to?
    When the only tool you have is a hammer, every thing starts to look like a nail
    Jul 2011
    Good point, didn't think about that. I'll have to check the reg's.
    Jul 2011
    Nothing in the reg's about it.
    Feb 2004
    back of beyond
    1098,xjr1300,525 tard
    44 times
    How long would one spend idling? Fan isn't needed above 60kph roughly.
    An would take a couple of minutes at stand still to get to hot
    Jul 2011
    Yeah, that's what i was thinking. And if it gets hot from being held in the dummy grid you can allways just turn it off.
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    112 times
    10 Post(s)
    At collie my bike runs at 90deg on a 31 deg day, so as it heats up so will your bike, every time I stopped it was on the fan. Is the weight loss that important for your level of competitiveness ?
    Personally I will keep the fan
    Member XXX3's Avatar
    Oct 2007
    JB Racing Supersport ZX-6R
    30 times
    You definitely need a fan.
    People have removed one of two fans on their bikes and boiled the radiator *cough* Chitto *cough*. Also switching off the bike does not cool it down quickly - the coolant stops circulating and they actually get hotter in the short term. On really hot days over summer, by the time you've completed the cooldown lap and made your way to the pits the bike will be running hot. Remember also we have to run water to race which will boil at a lower temperature than coolant... not much margin for error.
    Additionally for superstock, in the rulebook there's a statement that basically precedes everything else saying "your bike must be as standard EXCEPT the following..." so if it's not mentioned, you'll are required to have it.
    Not for individual sale.
    Jul 2011
    Cheers, guys. Think the benifit of having a fan out weighs the weight saving...
    New Member
    Feb 2012
    You would loose more weight chucking a shit before a race then ditching your fan. For how much it weighs I think it's worth keeping
    Feb 2011
    520 times
    11 Post(s)
    You not only get held on the dummy grid at the start of a race, red flag situation may see you sitting there waiting for a restart and as previously stated, the engine temp increases once it's switched off.
    Nov 2011
    Nothin yet
    You can consider removing the thermostat though. Gives more coolant flow. Monitor however that she is not running too cool. Removing the fan also means higher air flow through the radiator. I would certainly try it and had it on my race bike (running it usually in 30 degree weather -hot day in temperate climate, normal around here)
    As to weight reduction and having a dump: I heard that a lot when I started asking a lot of questions of how to reduce the weight 33 to 50 % of every single piece that makes a motorcycle. Economists say "A billion here, a billion there and soon we talkin real money".
    A streetlegal bike like a CBR 125 at 127kg can shed 50 (fifty) kg on the way to become a race bike. What might a heavier bike be able to shed. It all ads up.
    To the issue with she heats up after stopping the engine. Cooling systems nowadays donīt work as thermosiphon cooling. Sometimes the fan comes on when she is stopped, but there is no actual cooling in progress...
    Some people have an electric driven waterpump. The one used in Wabco park heaters is pretty awesome for that application. You can adjust the waterflow, the waterflow is usually higher than with the motor driven one, the engine can actually be cooled when she is stopped after the race (with a fan installed that is), More horse on the crankshaft if driveline is removed, and if the bike has no alternator and is running on battery only, there is even more horse on the crankshaft...
    Inactive Member Heretic's Avatar
    Sep 2005
    Kawasaki
    42 times
    Quote Originally Posted by ripper1199 View Post
    nice, what was your race bike?
    I cant help it if my reality doesnt match your perceptions
    Nov 2011
    Nothin yet
    CBR 138RR. You can see the electric waterpump in front of the motor. The Plug just left of it is covering the hole for the original waterpump. Driveline was removed so it needed filling.
    Member SomeBloke's Avatar
    Feb 2012
    2012 Hyosung GT205R Black/White
    3 times
    I build open wheeled race cars as part of a worldwide university competition (motorsport.uwa.edu.au) some teams decide to run without a fan and quickly learn that a fan is necessary, fans move air over the radiator elements, if you are stopped for what ever reason your temp will continue to rise, sometimes even moderate speeds dont allow enough air to pass over the elements, we use an RC plane motor (brushless) and blades from an online shop (being a uni team students run research projects on various blades) we have an insanely light package and a really energy efficient one at that.
    I would leave the thermostat in unless you have an electric waterpump (with which you can control water flow at different speeds).
    If you cook an engine because of leaving a fan off you will be kicking yourself, murphy hangs around waiting for these things..
    Member headbolts's Avatar
    Jan 2009
    DRZ440E-SM, DRZ400E, YZ450F, KLX 250R
    FYI when you remove the thermostat it does take longer for the bike/car/whatever to warm up and reach operating temp, but once there alot of bikes/cars ect run hotter actually with no thermostat as the coolant flows faster as isnt restricted by the thermostat anymore and passes through the radiator quicker so it doesnt cool down as much.
    F@#k the whales... Save the 2 strokes!!!
    PSB Corporate Sponsor PREMIUM SBK Toy Store's Avatar
    Sep 2008
    Stuart, Florida, United States
    Yamaha R6
    My racebikes have always been fan-less. I haven't hurt one yet (well, at least not from removing the fan...).
    PATRICK A. MCNEALY
    President
    Superbike Toy Store, LLC
    (P) 772.283.4926/Toll Free: 866.999.9823
    (F) 772.283.4956
    questions@superbiketoystore.com
    http://www.superbiketoystore.com/
    Member TheBrad's Avatar
    Aug 2010
    Loonylup
    An awesome one!
    24 times
    Quote Originally Posted by headbolts View Post
    Spot on.
    Also as the bike is cooler it richens your ratio to compensate for the colder temp meaning more fuel needs to be carried.
    Apr 2009
    Walliston
    Pumba
    401 times
    11 Post(s)
    Quote Originally Posted by SBK Toy Store View Post
    How does your climate compare to Perth?
    Sep 2008
    Yamaha R6
    Hot and steamy (think India).
    PATRICK A. MCNEALY
    President
    (F) 772.283.4956
