Perth Street Bikes
Go Back   Perth Street Bikes > MOTORCYCLE TOPICS > Mods, Being Technamikle & Product Reviews
Mods, Being Technamikle & Product Reviews Mods, general bike mechanical discussion & product reviews
Reply
LinkBack Thread Tools
Old 29-06-2007, 08:36 PM   #1 (permalink)
white 2004 ZX636 + white 2001 F4i stunter
Joker's Avatar
STICKY THIS as i wont explain it again.......
this mod will work for ANY kawasaki that has one the low beam as the left light........ it took me a while but i figured it out. here is a write up on how you go about it.
well, Sista said she was annoyed that Kawasaki in their infinite wisdom made the left light only for low beam. so whilst she is away in Europe (with her permission ) i decided since i am off work to fix the problem.
heres what you need for a start....
a 5 pin, 30A relay (if you dont use a switching relay, you WILL melt your plugs, wiring harness and be up shit creek)
2 x H4 socket plugs for headlights
2 H4 bulbs ( the one on the right is the stock h7, notice the difference in size. We are going to have to modify the H4 to fit into the stock headlight)
Tin snips
and finally some wire strippers, electrical tape, and needle nose pliars.
First remove the headlight
(if you need pics for how t do this, do not do this mod. It will be way above your mechanical ability)
next, remove the two circle covers on the back of the housing
pull the sockets off the headlights, remove the rubber circle in the center of the headlight and pull the wiring out throught the hole
now youll notice the h4 is too big to clamp into the housing, so take the tin snips and start cutting down the bracket on the bulb. Your going to have to cut off the outer lip, just keep trimming small amounts and checking to see when it fits. Yo have to remove the cone inside the housing on the low beam side. I reccomend baking it in the oven and removing the front glass to pull it out. Or you can use a heat gun or clow dryer to heat up the glue and pull it out. I just held it with a pair of needle nose pliars and started butting at it with the snips untill i wa able to bend it throught the hole but i did scratch the reflector housing a little. You can only see it when you look real close.
Wire in the H4 plugs with the ground, low beam and high beam wiring plan (once again refer to manula if you dont know this)
replace the covers
now follow the wiring diagram. Do not cut off the harness! you are going to connect the stock plug on the headlight harness into the stock plug on the bike. Cut off the headlight bulb harnesses and splice those into the relay wiring.
Make sure to cut off the rubber cover so you can re use it. You only want to cut the center so it is a single hole and slide it off the old wires.
Run the new wires through it
Tape all your connections
Put the headlights back in and enjoy!!
Headlights on and back together
Low Beam
High Beam
__________________
all my avatar pics are taken by Mags Williams
www.checkeredflag.com.au
Joker is offline   Reply With Quote
Old 29-06-2007, 08:41 PM   #2 (permalink)
BigTim's Avatar
Nice write-up mate.
Looks shit hot too.
__________________
The Industrial Revolution, has flipped the bitch on evolution...
--48 hours and counting--
BigTim is offline   Reply With Quote
Old 29-06-2007, 08:45 PM   #3 (permalink)
foolishboy's Avatar
Awesome job there Joker, hmm got the same problem with my 'blade, would be nicer if both headlights lit up.
foolishboy is offline   Reply With Quote
Old 29-06-2007, 08:46 PM   #4 (permalink)
DRKSIDE's Avatar
Excellent job Joker. Youve explained it really well
__________________
Damo
DRKSIDE is offline   Reply With Quote
Old 29-06-2007, 09:03 PM   #5 (permalink)
99 YAMAHA R1
Orson's Avatar
I'm blessed in that my model of bike is already equipped with dual (H4 also) headlamps. But still wanted to congratulate you on taking the time to do that Joker. I'm sure there are a tonne of peeps who'll be ever grateful and use your advise on this mod. Now you can look forward to wankers flashing you cos they think you've got your H/Bs on. Then they really cop any eyeful when you flash them back with your actual high beam. he he he. Once again, good job
__________________
"What's the lap record and which way 'round?"
Orson is offline   Reply With Quote
Old 29-06-2007, 09:09 PM   #6 (permalink)
Stu
CBR1000RR
Stu's Avatar
Top write up Joker.
__________________
Rossi: Honda -> Yamaha
Stu: Yamaha -> Honda
Spiral out, keep going.
Stu is offline   Reply With Quote
Old 29-06-2007, 10:17 PM   #7 (permalink)
Joker's Avatar
thanks for the replys guys....... i am pretty positive the girly will love it
oh, and took approx 5 hours (cause i have never puled a Kwaka apart b4) and cause i had to remember my relay theory
__________________
Old 30-06-2007, 01:07 AM   #8 (permalink)
Just a bunkie.
Hornet's Avatar
PICSOFSISORBAN.
Good write up... I know a guy with a 'Blade that might be able to use that for his.
Hornet is offline   Reply With Quote
Old 30-06-2007, 01:17 AM   #9 (permalink)
Joker's Avatar
hahahha thats her mum in the background Hornet
she is in Europe at the moment, which is why i am pulling her bike to pieces hehehehe
__________________
Old 30-06-2007, 01:22 AM   #10 (permalink)
Just a bunkie.
Hornet's Avatar
Her mum?
Ooer... don't mention that word around here... Savi might hear and that wouldn't be good for anyone.
Nice to play with other people's toys while they're away, aint it?
Old 30-06-2007, 01:26 AM   #11 (permalink)
Joker's Avatar
SURE IS!!!!!!
she said on her wish list was a fender eliminator, and to somehow get the low beam on both sides..... i have achieved both
with a broken shoulder too hahahaha fucking hurt it a lil today tho. whoops
and yeah, the mod should work on a blade, but the wiring will be a lil different (makes of bike diff) but it shouldnt be too hard to figure out
__________________
Old 30-06-2007, 09:06 AM   #12 (permalink)
One i can afford
Top work Joker, might use this in attempt to do the 10.
Might be a bit harder though, different lenses.
Good write up.
__________________
Elmoh's not fucking dead, just dormant.
I am not sorry for being honest againt thos who want to push evey little 250 rider around!!!!
Elmoh is offline   Reply With Quote
Old 30-06-2007, 09:49 AM   #13 (permalink)
06 Ninja ZX-6R 636
Viper's Avatar
i'm gonna do this and the HID conversion at same time. I'm ordering in a HID H4 BI kit and doing this mod. I'll take some piccies along the way.
Might be a couple weeks though
__________________
Quote:
Originally Posted by Col View Post
Not if I dont give you your bike back! I must say I have enjoyed it this last couple of times I rode it! (I knew you like Kwakas Col )
Quote:
Originally Posted by FJ Steve View Post
Wherever your kwaka goes, always believe that the FJR will be following...(I might be quite some metres behind...but I'll be following)
Viper is offline   Reply With Quote
Old 30-06-2007, 10:34 AM   #14 (permalink)
Black one and a blue one
Twinks's Avatar
Yeah very cool write up. Might stop every second person telling me i have a headlight out.
And its always good to have someone work it out for ya.
__________________
Only motorcycle riders understand why dogs stick their heads outside car windows.
Twinks is offline   Reply With Quote
Old 14-01-2008, 12:18 PM   #15 (permalink)
06 Ninja ZX-6R 636
Viper's Avatar
oooops
Old 14-01-2008, 12:24 PM   #16 (permalink)
YZFR1 '03
Bunyack's Avatar
great right up. one reason I dont like a lot of the newer model bikes is this reason.
__________________
Quote:
And the fact that the insane power of the R1 is near-on un-applicable just makes it that much more entertaining.
Bunyack's awesome exhaust: http://www.youtube.com/watch?v=tUQtIaZ0IDU
Bunyack is online now   Reply With Quote
Old 04-07-2008, 09:00 AM   #17 (permalink)
Joker's Avatar
Bump, for newer members with the 1 headlight problem
ps:- currently doing a writeup for a Dual headlight HID conversion for an 06 ZX636LE... did it to MrMez's bike
__________________
Old 14-07-2008, 08:25 PM   #18 (permalink)
ZX10R
Pobbler's Avatar
I did mine a year ago... best mod ever!!
__________________
the grass is greener on MY side
Pobbler is offline   Reply With Quote
Old 31-07-2008, 01:47 AM   #19 (permalink)
YZF-R6 2005
B.six's Avatar
bah iv been looking into it 4 my R6 because the ports are already there for the globes so it can have an R1's light config. From what i can gather from the yanks tho its a bit of cutting and grinding and i was never good with electrics....i remain 1 headlight out
Is this workable joker?-
http://www.palehorsecycles.com/howto.pdf
__________________
B.six is offline   Reply With Quote
Old 03-08-2008, 10:27 PM   #20 (permalink)
08 FZ6n
MattyA's Avatar
a tad off topic but can you up the wattage of standerd 55/60 gloves to higher ones without fear of melting the reflector/housing?
or hang a couple of dirty big spotlights from the forks.....
^fugly
MattyA is online now   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
» Sponsors
» Current Poll
PSB CHAT!!
Yes, I use the PSB CHAT - 46.67%
7 Votes
NO, I Didn't even know that they had one!! - 53.33%
8 Votes
Total Votes: 15
Advertise on PSB
