03-09-2008, 04:38 PM
#1 (permalink)
2001 Ducati 748R
Ducati wheelie problem
It's not a problem with the wheelies, more a problem with it dumping copious amounts of oil up through STM breather and into the airbox, which then leaks fucking everywhere.
Any suggestions on how to fix this problem other than stop doing wheelies, because honestly, that isn't really an option.
EDIT: Evidently, I fixed my clutch.
__________________
03-09-2008, 04:40 PM
#2 (permalink)
Drop the motor.
Put an <insert any other manufacturer name> engine in there instead.
This is a fairly common complaint, Desmo.
"It's a ducati, officer. They do that"...
Just another part of the charm.
__________________
03-09-2008, 04:42 PM
#3 (permalink)
2001 Ducati 748R
Yeah, I know it's a common issue with the quattro/testastretta, just wondered if anyone had actually heard of a fix.
This is the second time in as many weeks this has happened.
__________________
03-09-2008, 04:47 PM
#4 (permalink)
Quote:
Riiiiiiiiight... *remembers ANZAC day*
Seriously though- Perhaps you could look at re-routing the crankcase vent elsewhere, like to a secured, but unsealed, bottle, that you'd have to check after riding for a while (similar to those PV drain bottles on RGVs).
__________________
The Industrial Revolution, has flipped the bitch on evolution...
--48 hours and counting--
Quote:
Cop: Who's in charge here?
Bunyack: That'd be you now, sir.
03-09-2008, 04:52 PM
#5 (permalink)
2001 Ducati 748R
Quote:
Yeah, she doesn't cut out anymore
Just having a read here, Oil Breather - Ducati Up North, might help some.
__________________
03-09-2008, 04:59 PM
#6 (permalink)
Jota | TZ350 | T160V | 'Storm
I purchased an oil breather for my last duck from Vee Two. I just did a search of their site and they don't appear to range them these days.
Maybe too busy R&D'in blowers or something...
S.
03-09-2008, 05:01 PM
#7 (permalink)
2001 Ducati 748R
Might look at a remote breather set up, it really is dumping a LOT of oil.
__________________
03-09-2008, 05:03 PM
#8 (permalink)
You don't think the fact that it's dumping a lot of oil is a bigger concern?
edit: Wait, it's only during wheelies, right? nvm.
__________________
03-09-2008, 05:05 PM
#9 (permalink)
2001 Ducati 748R
It's a well known issue with the 8 valve motors mate, due to where the breather sits.
It's OK if you do little mincy faggot wheelies, but if you hold it up for any length of time, it just spews it out the breather and up into the airbox.
__________________
03-09-2008, 05:09 PM
#10 (permalink)
You have no idea how much self control I'm showing here.
That stuff in the article about a breather with small oil-catching tube thingos sounds like an alright idea.
Is the "STM breather" already an after-market job?
__________________
03-09-2008, 05:13 PM
#11 (permalink)
2001 Ducati 748R
Just checked, and surprise surprise, it's not a fucking STM.....
I swear one day I'll find something on this bike that's as advertised.
Going to pull it apart and look at it inside, but I'd bet bcks that an OEM one would do a better job than the cheap $25 ebay one on there.
__________________
#12 (permalink)
oil catch can + breather vent would sort this I would think? (located somewhere smart)...
preferably a baffled can so that the oil doesnt surge out the breather during quick acceleration/deceleration
__________________
Project Magic Surf Bus
BEER, SURF, BEANBAGS, CHEAP SPRAY CANS, MUSIC, BEACH, NAKED - WHAT MORE COULD YOU WANT?
03-09-2008, 05:34 PM
#13 (permalink)
Ducati 1098S
Wasn't that the whole point of the STM breather mod? Maybe replacing it with the real deal will fix the prob?
03-09-2008, 06:14 PM
#14 (permalink)
98 R1 - Blue Goodness
Yep, I would go for a catch can that is internally baffled but also vented to atmosphere via a filtered breather (that way it doesn't build up pressure and start blowing out gaskets/seals). Then just seal off where it would normally feed into the airbox.
There are heaps on the market that are designed for cars, just check eBay and I'm sure you will find one that is small enough to be adapted to the bike.
Will also help ensure that the oil vapour won't mess with your air intake system (air/fuel ratios) - which is usually why they are put on cars.
__________________
03-09-2008, 06:17 PM
#15 (permalink)
Run an oil catch can dude
__________________
My apologies for the yamaha in my avatar.
Quote:
KylieJane says:
i quite like sairz
KylieJane says:
maybe i should scissor her
03-09-2008, 06:39 PM
#16 (permalink)
CBR600RR7, 1.5x VJ22 RGV250
just drain the oil out of it and run premix.
__________________
310rwhp 180sx for sale. most bolt ons (turbo, injectors, ecu, brakes, suspension, etc), $11k. pm for details
New to riding? Or group riding?
03-09-2008, 07:37 PM
#17 (permalink)
996, Daytona 675, RM250, CR125
Make sure the replacement breather has a carbon reed, they work a hell of a lot better than the plastic ones.
No you can't have mine
__________________
The 996 mods: Stealth look Termis, JhP High flow air filters, Eprom chip, DP Monoposto, LED tail, DP Light weight Flywheel, Hardened Chrome Rockers, DP Sprocket cover, DP Carbon Exhaust guard, Tinted screen, Front Number Board, DP Ergal Fuel filler, STM Superbike quick chance sprocket carrier, STM Oil Breather, STM clutch cylinder, DP fender eliminator, DP Carbon Hugger, Carbon Heel Guards, Warpspeed Rad Guard, Carbon Air Tube Covers, Carbon Key Guard, Carbon Instrument Cover, Titax Levers.
03-09-2008, 10:58 PM
#18 (permalink)
2007 Ducati SC1000bip
i ve got a stock fairly low kays oil breather from my sc1000 sitting around you are welcome to try that and see if it solves or helps your problem (if it fits)
the other thing - isnt your motor fairly worked and all that , so could it be generating more than the usual internal pressure which is why it venting so much oil especially under high rpm and up steep hills???
__________________
" West Coast Cafe Racers"
04-09-2008, 02:47 AM
#19 (permalink)
Ducati 916 Bip, ZX6RR for da track
Jules_1972 has the carbon underseat tray & oil catch combo, works a treat but not a cheap option, PM him for info
04-09-2008, 07:44 AM
#20 (permalink)
Quote:
LOL - subtle
S.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
» Sponsors |
