Results 1 to 12 of 12
Thread: front sprocket removal
    Nov 2006
    Perth WA South
    Yamaha R6
    Ok a need a little technical knowhow on how to remove the front sprocket nut of my 99 r6. Essentially the chain and rear sprocket have been removed, and the front sprocket is still in place (im starting to realise this was a bad order of removal).
    Issue is, when i go to loosen the front sprocket nut, it just cranks the engine over (when in gear). If i had left the chain etc in place first, i could of just wedged the chain and rear sprocket in place, seizing the drive train, and allowing removal of the front sprocket.
    i digress, can someone advise a method on how to remove the nut, given that the chain and rear sprocket are now gone, and cannot be used in the process.
    cheers
    James
    Member bertie's Avatar
    Jun 2005
    Perth, NOR
    Cagiva Mito
    rattle gun
    SOR, near the airport
    474 times
    14 Post(s)
    in 1st. rattlegun. fingers crossed you don't fuck your tranny.
    OR get hold of a chain and rear sprocket, throw them back on and use the... back brake
    Staff Dubs's Avatar
    Mar 2003
    The PSB Café
    Hybrid Busa
    31 times
    14 Post(s)
    we did mine last week with a rattle gun, was the bestest way to do it
    Dubs
    Nov 2006
    Perth WA South
    Yamaha R6
    these rattle guns cost much?
    Member Desmo's Avatar
    770 times
    52 Post(s)
    Got a compressor?
    Jun 2005
    Perth, NOR
    Cagiva Mito
    a good battery powered one is about 600. then u gotta buy a set of 6 point sockets.
    Air powered is cheaper if you have a compressor already
    Member strawman's Avatar
    May 2005
    Corporation of Commonwealth of WA, slave quarters
    so police can target me
    do Bunnings or hire shop have them?
    i used an electric one from work, worked a treat with chain on.
    770 times
    52 Post(s)
    Pop the rear sprocket on, wrap the chain around it, wrap it around the front sprocket then stand on the brake and undo.
    You shouldn't need a looped chain for it to work.
    Nov 2006
    Perth WA South
    Yamaha R6
    omg cheers desmo. Just did that with my broken chain and dad on the rear brake. What a tough mofo!
    again cheers
    770 times
    52 Post(s)
    Awesome.
    Moderator Barfridge's Avatar
    Feb 2005
    ZX-7R
    815 times
    52 Post(s)
    onya Desmo! Top stuff mate
