I'm looking at buying a cheap FZR 250 and was hoping to get some advice. At the moment the bike runs fine with the exception that it sometimes has trouble changing gears. If you fiddle with the shift lever and the shaft it hinges on to, the gears work again, but it soon stops again. The lever moves up and down, but doesn't change gears. I want to get this problem resolved before I get the bike, in case it is going to be expensive to fix.
The guy who owns the bike reckons it is due to either the shaft (A) being bent or the bearings in the joints (B ) being a bit too worn. I've noticed that the sprocket that C rotates has a little movement - it leads directly into the bike and slides back and forward about 1mm.
If anyone has and idea what this problem could be, and the best way to address it, I would appreciate any advice.
