Results 1 to 14 of 14
Thread: GPX Electrical problem ??
    Member SIKYSA's Avatar
    Jan 2011
    Midland
    GPX. Working on an 88' zx10.
    Hi!
    I have been riding my little GPX to work and back since June. Have done over 14,000kms on her since picking her up.
    I've always changed the oil and filter every 4-5kms and have just changed the spark plugs last week.
    The problem that I am having is that maybe once a week (over the past month or so) the bike will simply die. I have been doing between 60-80km/hr then nothing. Engine stops, tacho reads 0 and there isn't any power. Then, an instant later she fires back up and all is good!
    Doesn't happen very often. I know last time it happened I was going over rail lines. Bumpy ones. Maybe a broken ignition coil ? What do you think ?
    Thanks!
    Jan 2012
    Kawasaki GPX250R
    no idea mate but love your avatar!
    Jan 2011
    Midland
    Haha, thanks. I was heading to work and a guy I work with noticed me there and decided to take a pic for me. What a legend! I'm just disappointed once I have my big bike I'll have to change it
    Member Nero Diablo's Avatar
    Oct 2004
    Out there
    21 times
    The obvious have you checked your battery terminals one might be a tad loose.
    Jan 2012
    Kawasaki GPX250R
    I still got 12 months until the big one
    Jan 2011
    Midland
    Comet- You'll get there in no time! Do what I did and buy an old school super-bike to do up while you wait.
    Nero- Connections are firmly screwed in place. Should I pull them off and give them a scrape with a wire brush or something anyway ? Maybe some gunk got between them ?
    Oct 2004
    Out there
    21 times
    Can if you want what about where the earth bolts to the frame. How gummed up with chain lube is the side stand cutout switch?
    Jan 2011
    Midland
    Haha.... very gummed up. There was a point recently it dripped onto the exhaust and smoked for 20 minutes. You think it's messed with the switch?
    Oct 2004
    Out there
    21 times
    Quote Originally Posted by SIKYSA View Post
    You won't make it worse by cleaning it.
    Member filbert's Avatar
    May 2009
    bunbury
    454 times
    28 Post(s)
    If it's cutting out on bumps also check the sidestand springs it could be bouncing enough to trip the switch.
    Jan 2011
    Midland
    Will have a good clean and check tomorrow and report back!
    Jan 2011
    Midland
    Ok so I cleaned the switch up (wasn't that bad actually) and gave the connections of the battery a clean. I suppose now I just wait and see if it does it again ?
    Member GSX IN SHED's Avatar
    Jun 2010
    Karratha
    honda suzuki
    16 times
    yeh .....OR start up in neutral/securely parked....give yourself access to wiring harness,doesn't matter where,If you like start at the sidestand switch wiggle/push pull wiring. Now remember to do one thing at a time--if it cuts out/misses etc....check along harness till you find corroded plug etc.
    fix as reqd......
    Test riding to find fault could cause critical failure ( the bike or you ) Try to locate problem before hittin' the tar!
    ''I am old and cannot see well.........I wait for water to be brought to me." Cheers' 'n all the best..
    Jan 2011
    Midland
    Didn't give me any problems yesterday (I even went and deliberately crossed those bumpy railroad tracks again!) but will sit down with her for a bit and play with all the connections to find out.
    Thanks !
