Results 1 to 7 of 7
Thread: GPX250 stator issues - Help!
    New Member
    Sep 2009
    Pearsall
    Kawasaki GPX 250
    Unhappy GPX250 stator issues - Help!
    Hey,
    I got a GPX 250 2000 model, done about 31k on the clock. a week ago my battery died, so I put it on charge overnight and it charged fine and held charge, put it back in the bike went for a ride and re checked the battery and it was 25% depleted. I took the bike to battery world where I purchased a new battery 6 months ago and they said it was the alternator. I supidly took this advice and went to two wheel wreckers and got a second hand stator. I swapped the stator over with the second hand one and started the bike and still the battery is not charging. I think it is generating enough charge to run as I can ride it with many starts over 2 days but then need to manually charge me battery.
    I have a multi meter which I put over the battery and while running it sits on 12.5v, with the highbeam and indicator on its 12.2v after turning them off it goes back up to 12.5v.
    I have checked all fuses in the fuse panel and also the main 30a fuse and they are all fine.
    any ideas on what is wrong with it would be great?
    I can't imagine both stators are faulty?
    Thanks in advance.
    Member GSX IN SHED's Avatar
    Jun 2010
    Karratha
    honda suzuki
    16 times
    That's not good...a bit unlikely that the stators are both faulty...?
    Check the connections ( plug) at the regulator ..and 'search' charging problems ...will be some great advise on here .. as you're not the only one to have this sort of problem .....good luck!
    Member fredie's Avatar
    Jun 2007
    Sydney
    CX125
    20 times
    no good . who changed stator's ? .
    Member smokeymatt's Avatar
    Oct 2007
    Beechboro
    GSXR 750. GS1000st
    the readings show your battery is not charging, it is unlikely that the regulator would fail or the stator i reckon you should check the continuaty of the yellow wires from the stator to the reg/rect. it might be as simple as a bad conection.
    I'm Living the dream.
    New Member
    Sep 2009
    Pearsall
    Kawasaki GPX 250
    I changed the Stator myself, it wasn't the smartest move as I had no idea what I was doing but it went back together okay.
    Ah, yep ill trace them wires tonight and look for bad coneections / corrosion I hope it is that simple as I really dont want to have to change the stator again lol.
    I searched the forum and found a post from a guy who had a trouble shooting guide, only problem is the link is dead so no guide.
    New Member
    Sep 2009
    Pearsall
    Kawasaki GPX 250
    Okay, well turns out the regulator was fried. Lesson learnt next time just take to the shop.
    Jun 2007
    Sydney
    CX125
    20 times
    good work . do you still have the original stator
Tags for this Thread
