Results 1 to 12 of 12
Thread: Helicoil/Thred Repair thing Installation
    Member Sharky's Avatar
    Oct 2011
    North - way north
    Aprilia RS125 & Ducati 1198s
    19 times
    Hi All,
    Does anyone know of a place which would install a Helicoil or similar thred repair type thing-a-ma-jig?
    Basically my Clutch Adjustment Bolt has stripped it's thred and looking for a temporary fix whilst I wait for my new Clutch Cam to arrive form italia
    Thanks guys.
    Member kennyboy's Avatar
    Sep 2009
    perth hills
    2012 z 750
    43 times
    Wat size and material is it? Blind hole?
    not everyone wants to pickup trash from the side of the road, leave it for the crims and the junkies.
    Oct 2011
    North - way north
    19 times
    Its soft as fuck aluminum. Nope the hole goes straight through to the pressure plate ballbarining. Current Thred size is 6mm.
    See attached The part i'm taking aobut is the little bolt and nut which is indicated going through the clutch cam (Item 3 on the drawing), the clutch cam is where the thred should be Rs125-CLUTCH-Break-down-photo.jpg
    Member emrys74's Avatar
    Nov 2008
    Westfield
    07 Sprint & 05 Smoto Burg
    102 times
    7 Post(s)
    Not tempted to have a go yourself just get the kit from cov's
    or any engineering shop can do it.
    be best to put an insert in the new one if its ali as it will be stronger and resist stripping.
    Oct 2011
    North - way north
    19 times
    Thanks Emrys, This bike is turning me into a mechanic anyway so may as well see what a kit is worth, probably won't be the first time Will also phone around some engineering shops to see what $$ they are after as I'll probably fuck it up and end up costing me more anyway
    By insert do you mean something like a Avdel Thred Insert?
    Nov 2008
    Westfield
    102 times
    7 Post(s)
    yeh heli coil, werts, recoil inserts there are heaps of them out there its prety easy if you got a drill press or you got to be cairfull not to drill it out on the piss. use plenty of lube or thread cutting compound when taping. when done if done right will be better than the original and would be unlikely to ever strip i put inserts in a lot of ali if im going to be running bolts in and out a bit.
    Oct 2011
    North - way north
    19 times
    Quote Originally Posted by emrys74 View Post
    or you got to be cairfull not to drill it out on the piss. .
    well im fucked then. :p
    Sep 2009
    perth hills
    2012 z 750
    43 times
    It's pretty hard to fuck it up, if you have any hand skills it's piss easy.
    Have you got the part out and on it's own?
    Member pearcey's Avatar
    Oct 2011
    Suzuki GS1000st
    6 times
    Quote Originally Posted by kennyboy View Post
    Ditto this. I'm basically crap at anything mechanical really, and almost always fuck things up at least the first time, but somehow managed to Helicoil several bolt-holes on my NC30.
    Member G-Bek's Avatar
    Nov 2010
    Lesmurdie
    KTM 640SM, CRF250R
    if you can get it into a drill press set it up square (as in, not drilling on the piss) and drill the correct sized hole. leave it set up in there and put a center in the chuck. the back of the tap should have a center hole in it, use this to keep the tap straight until you get the first few threads in. one turn forward, half turn back to clear swarf. don't fuck up the first few threads or it will turn into a crap job. enjoy
    Yes officer, I did see the speed limit sign. I just didn't see YOU!
    Nov 2010
    Lesmurdie
    KTM 640SM, CRF250R
    if you can't guide the tap with a center, when you start the thread, if it goes in a little bit pissed, straighten it up as you're cutting. if you try to keep re-starting you'll completely cross thread the start of it and end up with an ugly oversized hole. once it first bites into the metal, use some kind of square to true it up. don't tap too deep and try to straighten it cos again, you'll fuck it up
    Oct 2011
    North - way north
    19 times
    Damn phone stopped giving me updates on this thred. Thank you all for your help. I'm all sorted now!!!
