Perth Street Bikes
Go Back   Perth Street Bikes > MOTORCYCLE TOPICS > Mods, Being Technamikle & Product Reviews
Mods, Being Technamikle & Product Reviews Mods, general bike mechanical discussion & product reviews
Reply
LinkBack Thread Tools
Old 02-07-2008, 03:41 PM   #1 (permalink)
YZFR1 '03
Bunyack's Avatar
Help! I think my clutch has Sh*t itself. Pics of plates on p5.
During a spirited ride last night, I think my clutch shat itself.
was at a set of lights, waiting for green, in first gear, clutch lever in, lights go green, clutch lever out, throttle on, It stalls.
Clutch lever in, start her up again, clutch lever out, throttle on, it stalls.
this happens a few more times and I manage to start without the cluth, just with throttle. park her up on the corner of a street somewhere up north (North Beach Rd). A quick sms and the rest of the ride finds me.
So.... the symptoms:
When the bike isnt running, (just the electrics on) I can change through 1st Neutral and 2nd easily.
when the bike is running, in Neutral, it slams into 1st with a lot of force. (Clutch lever in of course)
when the bike is running, in Neutral, and I pull the clutch lever in, the clutch basket makes a wirring sound, as if things are rattleing in there.
When the bike is in 1st, it wont change up into NEutral, and skips straight to 2nd, with a lot of force.
When the bike is in 1st, with the clutch lever in, the bike is pulling forward, as if the clutch is slightly engaging.
I was hoping it was a simple cable adjustment, but now im fearing it is something more sinister.
any suggestions???
yes it may be because I thrash the bike, I know its most likely the cause, you dont have to remind me. But I stay away from clutching it, most of them are power'd up.
__________________
Quote:
And the fact that the insane power of the R1 is near-on un-applicable just makes it that much more entertaining.
Bunyack's awesome exhaust: http://www.youtube.com/watch?v=tUQtIaZ0IDU
Bunyack is offline   Reply With Quote
Old 02-07-2008, 03:49 PM   #2 (permalink)
Hyobusa GT1300R
Captain Starfish's Avatar
so you've effectively lengthened the cable run at both ends? ie wound the adjusters out away from the levers?
If it's just an adjustment then this should mean that the clutch is permanently "pulled in", ie can click gears with engine running, let clutch out and nothing happens.
But for the bike to stall when you let the clutch out sounds a little more sinister...
Quote:
When the bike is in 1st, it wont change up into second, and skips straight to 2nd, with a lot of force.
<-- fix this please, makes zero sense as written.
How did you end up getting home?
__________________
Look after yourself? A newborn fawn could crush you with its forelimb, you Man of Margarine...
Captain Starfish is offline   Reply With Quote
Old 02-07-2008, 03:53 PM   #3 (permalink)
K6 GSXR750
semi's Avatar
uh oh
sounds pretty sinister to me too, maybe something warped bad in there. Was your bike running particularly hot bunyack? Did it do anything before taking off from the lights?
semi is online now   Reply With Quote
Old 02-07-2008, 03:55 PM   #4 (permalink)
YZFR1 '03
Bunyack's Avatar
ooops fixed. i meant it skips neutral.
Yeah, when it first happened, it stalled a few times. I rode for a few km, trying to alert the rolling corner marker ahead of me but her kept taking off when he saw me so I stopped.
when I had stopped, it didnt stall anymore. just the lurching forward when the clutch was in and in 1st gear. and the missing neatral while the engine's running....
__________________
Old 02-07-2008, 03:58 PM   #5 (permalink)
YZFR1 '03
Bunyack's Avatar
Quote:
it feels as if the cable is too loose, causing the clutch to be slighly engaged, I tried to tighten it, but didnt get any results.
if it's only a few hundred $$ for some new clutch plates that would be ok.
so long as the gearbox aint fuXored
__________________
Old 02-07-2008, 03:59 PM   #6 (permalink)
It goes
Aphex's Avatar
Gluck with that... full clutch pack is closer to $1k. Gearbox??? Get a 4th job
__________________
Aphex is offline   Reply With Quote
Old 02-07-2008, 04:00 PM   #7 (permalink)
K6 GSXR750
semi's Avatar
should only be a couple of hundred. I'll do it/help you do it if you want, theyre not really hard to do
Old 02-07-2008, 04:00 PM   #8 (permalink)
K6 GSXR750
semi's Avatar
hang on, im calling 5 star now
Old 02-07-2008, 04:01 PM   #9 (permalink)
YZFR1 '03
Bunyack's Avatar
go Semi!!! go!!
__________________
Old 02-07-2008, 04:05 PM   #10 (permalink)
05' R1 + 83' RZ250
nath's Avatar
Shouldn't cost you more than ~$200 for friction and steel plates fom somewere local.
Else... Ebay.. ~US$100 for a HD
Edit: oh.. + replace the gasket... $30-40
__________________
I told an admin to piss off an all I got was this lousy assigned image.
nath is offline   Reply With Quote
Old 02-07-2008, 04:07 PM   #11 (permalink)
K6 GSXR750
semi's Avatar
friction plates:$126
steels: $216
springs: $60
mate, drop your oil as soon as you can, and try not to ride the bike. If you've fucked the fibres then you should see it in the oil
Old 02-07-2008, 04:08 PM   #12 (permalink)
K6 GSXR750
semi's Avatar
yeh, plus oil and filter, plus probably some cheap oil for a flush
Old 02-07-2008, 04:10 PM   #13 (permalink)
05' R1 + 83' RZ250
nath's Avatar
Quote:
steels: $216
springs: $60
lol...
eBay Motors: YAMAHA R1 YZFR1 CLUTCH KIT PLATES GASKET MORE 1999 2003 (item 110265636507 end time Jul-03-08 16:31:42 PDT)
Filter is $16-20 local
__________________
Old 02-07-2008, 04:14 PM   #14 (permalink)
2004 YZF-R1
Halo_2's Avatar
noob wheelie's
on a rear stand in nuetral the rear wheel shouldnt spin at all
try adjusting it first 2mm slack at clutch lever before it engages before buying new plates, guessing it wasnt adjusted properly and your burnt your plates.
i payed about that for the zzr to be fitted by stealership
__________________
RiDe F@sT.. HaVe FúÑ).. PlAy LõÚd.. DiE Þ®øûÐ
Halo_2 is offline   Reply With Quote
Old 02-07-2008, 04:14 PM   #15 (permalink)
K6 GSXR750
semi's Avatar
thats not much cheaper, its the steels that are the killer, which arent in that kit
Old 02-07-2008, 04:15 PM   #16 (permalink)
K6 GSXR750
semi's Avatar
Quote:
Originally Posted by Halo_2 View Post
noob wheelie's
what?
Old 02-07-2008, 04:17 PM   #17 (permalink)
05' R1 + 83' RZ250
nath's Avatar
There will be one that does... CBF looking..
__________________
Old 02-07-2008, 04:17 PM   #18 (permalink)
rgvlee's Avatar
noob wheelie's
This is not correct.
There is a thread covering this very well on the forum. The rear can and will spin to a degree in neutral.
...back on topic
edit: http://www.perthstreetbikes.com/foru...uestion-37103/
rgvlee is offline   Reply With Quote
Old 02-07-2008, 04:17 PM   #19 (permalink)
K6 GSXR750
semi's Avatar
eBay Motors: YAMAHA R1 YZFR1 CLUTCH KIT COMPLETE PLATES GASKET 99 03 (item 300237063975 end time Jul-03-08 16:31:44 PDT)
This ones much better, comes with all the frictions, steels, boss ring and gasket. Much better price
Old 02-07-2008, 04:19 PM   #20 (permalink)
YZFR1 '03
Bunyack's Avatar
awwwww, just did the oil and filter
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Search Engine Friendly URLs by vBSEO 3.1.0
Advertise on PSB
