Hey,
Thought i'd change the oil on my zzr250.
Anywho, took it for a ride to get it warm, parked it on its centerstand and then removed the oil plug bolt and let the oil drain for 15 mins.
Put the bolt back on and tightened with my hand, then used a torque wrench (14.5 lb/ft as in manual) yet it just kept turning.
I soon (10 rotations or so) realised and took the bolt off, searched through the oil pan and found a washer
Put the bolt and washer back on, hand tightened then torqued but now it just keeps turning, going from kind of tight back to loose, as though its turning off its grooves.
Took bolt off again and little bits of curled metal are on the bolt.
What have I done? How bad is it? Whats the next step?
Cheers guys.
