Helped a mate replace a tank on an R1 yesterday, switched all the fittings over after draining the tank, reconnected the wiring, fuel ine and vaccuum lines and refilled with fuel. But now she will turn over but won't start.
Have checked and rechecked the wiring connections, vaccuum hoses and fuel line, all to no avail.
Battery was fully charged (so it can't be cranking issue), no fuses blown.
Does any one have any ideas as to what might have happened or is there a 'trick' that I am unaware of.
Also, the fuel pump discharges fuel from the connector when the tank is upside down, so fuel is obviously getting to the line, but perhaps the fuel system is pressure based and without the correct pressure, it won't fire ?
Any help would be much appreciated.
