Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: How to use water wetter?
    Guest
    Sep 2010
    How much water/ coolant and water wetter is a good mix for your bike?
    what temp range am i to expect when using it?
    Member filbert's Avatar
    May 2009
    bunbury
    Ducati 916S, Hyosung GT250R, MCI Aquillo moped.
    4848 times
    238 Post(s)
    11 Thread(s)
    there are generally guideline instructions on the labels that will give you enough information to make a decision.
    Member Kiwi's Avatar
    Oct 2005
    Out of the purple circle!
    V2x2
    I used one bottle and distilled water in my ZX14, made a big difference to the operating temp when stuck in traffic etc. ZX14 does not have a temp gauge as such, just bars so I can't tell you exactly in degrees.
    You may need some coolant in the mix for the Winter months.
    Member jmoore's Avatar
    Mar 2008
    NOR Meetpoint
    185 times
    10 Post(s)
    im pretty sure it tells you on the box how much distilled water to add. I also believe it also claims how much it will reduce your temp range as well.
    If you using it to counter some overheating problem and blowing headgaskets ... not really going to help, your better off finding the actual cause
    Quote Originally Posted by polonY
    Don't worry about shitting people off. Unless you ride a ninja 250 or a cbr250rrrrrr
    Member darkfibre's Avatar
    Apr 2009
    Walliston
    Pumba
    1084 times
    47 Post(s)
    10 Thread(s)
    The difference water wetter will make is better heat transfer. Riding along the bike may run cooler, however stationary in traffic the bike will still heat up to exactly the same temp that the fan cuts in at. It may cool down quicker than beforehand after the fan cuts in.
    Glycol based additives act the opposite as water wetter, giving less heat transfer (but raising the boiling point)
    Guest
    Sep 2010
    awesome filbert, wondered what all that stuff said. thanks buddy.
    Guest
    Sep 2010
    Quote Originally Posted by Kiwi View Post
    how many litres in your radiator?
    Guest
    Sep 2010
    Quote Originally Posted by darkfibre View Post
    so the boiling piont with water wetter is?
    Guest
    Sep 2010
    im guessing after all that the best way to use it would be to add to coolant rather than distilled water as boil piont will be reached before fan cuts in?
    Member drifter's Avatar
    Apr 2009
    Vic Park-ish, Western Australia
    Honda CBR1000RR
    98 times
    17 Post(s)
    google will tell you everything you need to know.
    http://www.redlineoil.com/content/fi...ech%20Info.pdf
    202F to C - Google Search
    Here are some sites I've done recently - Velocity Race Team | Business Insurance | West Perth Insurance Broker | Perth Furniture | Final Trim Operators
    Apr 2009
    Walliston
    Pumba
    1084 times
    47 Post(s)
    10 Thread(s)
    Red Line WaterWetter® does not significantly
    increase the boiling point of water
    Guest
    Sep 2010
    its 250f with 15 psi radiator cap (121c) thats water and water wetter
    with 50% coolant its 265f (129c)
    Apr 2009
    Walliston
    Pumba
    1084 times
    47 Post(s)
    10 Thread(s)
    Back to basics.
    When stationary the bike heats up to 105 deg and then the fan cuts in. With normal cap pressure this is below boiling point regardless of water wetter or glycol coolant. If the bike then boils there is a problem requiring repairs.
    Guest
    Sep 2010
    so supplementing coolant with water wetter and distilled water with normal conditions wont damage anything?
    Oct 2005
    V2x2
    Quote Originally Posted by cbr1234mike View Post
    3.4 litres.
    Apr 2009
    Walliston
    Pumba
    1084 times
    47 Post(s)
    10 Thread(s)
    Correct, and as previously mentioned follow the instructions on the product.
    Disclaimer; You can damage things if you let the coolant level get too low, or introduce an airlock in the system etc.
    May 2009
    bunbury
    4848 times
    238 Post(s)
    11 Thread(s)
    rather than mess with coolant and distilled water etc. why not buy a few 5L bottles of premix coolant you can add your water wetter to that, and then you will always have the right mix for top ups.
    Guest
    Sep 2010
    filbert, did you just say something useful? give yourself a pat on the back mate
    *pats filbert*
    if running dis water and ww is hunky dory, then i might give it a shot for a while. the 5L coolant idea is good but i wouldnt mind seeing if it does improve things this way first.
    kiwi had success with dis water and ww on his zx14 in peak hour traffic conditions.
    Oct 2005
    V2x2
    Yes it worked a treat cooling down the 14, they are notorious for getting hot and bothered in traffic.
    So yes WW doe's work.
    May 2009
    bunbury
    4848 times
    238 Post(s)
    11 Thread(s)
    oh you wanted useful answers? i was always told ask a stupid question get a stupid answer so i thought i was helping
