Results 1 to 14 of 14
Thread: Need a welder to fix my shaft ====>
    Member Dark Shadow's Avatar
    Apr 2009
    South Lake
    Yamaha Fazer FZ1S
    17 times
    Hi folks
    I had a little mishap on our country run yesterday, I lost my gear selector shaft connection as the factory weld seems to have let go
    Wondering if anyone here could drop a small run around the join for me, unsure if it's a special type required such as tig or mig, so I have attached a couple of pics to show what's happened and what's required
    I'm in South Lake so if you're nearby all the better
    Thanks in advance
    Sep 2005
    34 times
    Check with magnet if it is steel, cast steel or cast alloy
    Apr 2009
    South Lake
    Yamaha Fazer FZ1S
    17 times
    Quote Originally Posted by Jamathi View Post
    Cheers Jamathi, put a magnet near both pieces and gives a good strong grab on both
    p.s. it's off my FZ1
    Sep 2005
    34 times
    Well then any MIG welder set up for steel can help you out.
    I am in Beaumaris, can/happy to do it fopr you, sadly for you it is like south Geralton.
    Apr 2009
    South Lake
    Yamaha Fazer FZ1S
    17 times
    Well thanks for the offer Jamathi, will see if anyone closer posts up in the next day or so, and if not, will prob jump on another bike and head up your way at a suitable time for you
    Member Renton's Avatar
    Aug 2008
    SOR
    08 FZ1N, 09 200exc
    3 times
    Hey mate. I'm in South Lake. Bring it round. PM sent with ph number.
    Can't ride for shit, but I fall really good!
    Apr 2009
    South Lake
    Yamaha Fazer FZ1S
    17 times
    Quote Originally Posted by Renton View Post
    ^^ Thanks for this offer, and to Jamathi for offering, should be sorted tomorrow
    Member SpeedTrip's Avatar
    Mar 2008
    S O t R __ Somewhere Over the Rainbow
    167 times
    I could help at work tomorrow afternoon, got mig and tig.
    But Greg, I think your Shaft needs a better work out than that,I can suggest a better way with happy ending
    Feb 2004
    back of beyond
    1098,xjr1300,525 tard
    44 times
    buy a new one you cheap arse
    Apr 2009
    South Lake
    Yamaha Fazer FZ1S
    17 times
    Quote Originally Posted by SpeedTrip View Post
    Thanks for the offer Rob, if the GF holds out on me I'll see you about that happy ending mate..!
    Quote Originally Posted by Falcore View Post
    I actually went straight to 5* on my way home from the ride to buy what I thought was the offending part, luckily for me as I was asking for the ball joint rod that screws down on the shift rod, they didn't have any, nor did 2 other yamaha dealers, it's only this afternoon that I got round to pulling it apart that I found it's actually the shift arm, and that poxy little ball joint rod that's all of 1" long was priced at $87
    So I wasn't actually cheap arse, just damn lucky that there was apparently none of the part I was asking for in Australia
    I did learn a valuable lesson, pull everything apart and check it out before guessing and rushing down to the bike shop to buy what you think is broken
    Member henrys's Avatar
    Nov 2011
    east freo
    GPz 750 from 1983
    20 times
    Yes I agree with that Dark Shadow, and it's often quicker, more satisfying and less wasteful of the world's finite resources to repair something that can still have plenty of life left in it, rather than just throw it away and buy a new one. Same applies to lots of perfectly good things that people throw away as soon as there's a slightly newer and shinier model available
    I for one refuse to join "the throwaway society", I doubt if they'd have me as a member anyway.
    At the other extreme, you have to remember not to waste time money and effort on fixing something that's not worth fixing, guilty as charged there
    Member Corona White's Avatar
    Jan 2008
    K6 GSXR600 Track Toy K7 GSX-R750
    Wreckers???
    Apr 2009
    South Lake
    Yamaha Fazer FZ1S
    17 times
    A big thanks to Renton, all welded up much better than new now, back on the bike and working fine
    Member robwas's Avatar
    28 times
    Awwww!! seems like there was a happy ending after all even without SpeedTrip's helping hand
    RR #100
    Sponsors Wanted.
