I've just been through testing the charging system on the 'Blade, and thought I'd share what I've found
(Might even be worth getting stickied?)
I was directed to this fairly comprehensive flow chart, and, armed with a multimeter and a bit of knowledge, you should be able to track down your charging issue.
Click Here for the guide, from ElectroSport Industries.
To give a little background and help to understand what it is that might not be working, I'll try describe the main components of the charging system, and what might go wrong. Feel free to correct me anybody
To power your motorcycle, you have three main components. The Stator (or Alternator), the Regulator/Rectifier, and the Battery.
The Stator converts the motion of the engine into electricity, producing over 50V of AC current, and outputs this current to the Regulator/Rectifier.
The Regulator/Rectifier first "rectifies" the current to a DC current, then "regulates" it to around 12V, or more, depending on engine speed at the time.
This new regulated current is fed into the Battery.
The Battery is charged by this current while the bike is running, so it can perform it's main function, which is to start the engine. From a standstill, the battery will power the starter motor, which will then mean the Stator is producing electricity, completing the circle of life
A basic understanding of this system will help you begin to diagnose electrical problems. I found this page pretty informative too![]()
First and simplest failure to fix is a faulty battery. When jump starting or push starting the bike will get it going, but it doesn't seem to recharge, you can take your battery to a battery place, or maybe an auto electrician to have the battery load-tested. If the battery is no good, replace it
If it seems like the battery is dead, but you've gone and had it load-tested, and it's not that, you will need to begin testing the rest of the charging system. It could be the stator, it could be the reg/rec, OR it could be a faulty connection somewhere between these components. Visually inspecting the different connectors for damaged/scorched wiring or tarnished/dirty contacts is a good start. If they are ok, the problem could be in either the stator or the reg/rec.
If either the Stator or the Reg/Rec fail, (in most cases) the bike will seem to behave like the battery is dead, failing to hold a charge. You may be able to run the bike for a while, but not start it next time, it may die on you mid-ride.
If a regulator/rectifier goes out in a big way, it could stop regulating the current, sending a much higher voltage out into your different components, possibly frying a lot of different things. I'd imagine this would have things like bulbs burning out, and magic smoke coming from different parts of your bike. If you think this may be happening, stop riding, before you fry anything important
Now, head to the top, open the Guide, and start hunting
I can't think of a great deal more to add to that, but Google, Wikipedia, and HowStuffWorks are all a great help if you want any more details on any of the bits mentioned above.
It seems mine has turned out to be a faulty stator, and using the guide, I was able to test the reg/rec on it's own, and it was fine. Very happy with the process, not so happy with the result![]()
