Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Like Tree1Likes
Thread: Problems with my PCIII USB
    Member shish's Avatar
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Hi Guys
    I'm having an issue with my PCIII USB on my 07 R1.
    I just tried to update the firmware. I managed to check the firmware on the PCIII and it was a previous revision. So I downloaded the latest Firmware version (Ver 2.3.2).
    I noticed when I turn the ignition on, the PCIII unit has a meter and the lights would come on and cycle up and down the meter with green lights. I tried to update the firmware and it said it failed and after that the meter was no longer doing that. Instead 2 green lights would stay on. The second light from the top and the second light from the bottom. I have attached an image to show what I mean
    When I try to load a map is keeps saying "Error Programming Module"
    And when I try to start my bike the lights do the same thing and it just turns over but doesn't start.
    Any help would be greatly appreciated
    Thanks
    Do or do not. There is no try
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    117 times
    you need to sucessfully reflash firmware before it will work
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Ok thanks
    Any idea what them lights doing that means?
    Sep 2004
    RZ250-R
    117 times
    it doesnt matter what the lights mean but i can take a guess- ERROR END RUNTIME
    there is no temp file (ala windows installer) to unpack into with a firmware flash, no roll back. you are writing directly into EEPROM. if the flash fails the command code is incomplete and/or corrupted and it wont work. reasons for flash failure are either incorrect firmware, comms fault during flash, hardware failure.
    Member reddog's Avatar
    Oct 2005
    Allanson
    Suzuki Bandit 1250SA
    I thought you needed a 9v battery to flash the PCIII's???
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    You can also supply power to the unit by turning the bike on apparently
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    I just tried updating the firmware with the PCIII USB Reprogrammer and it says its not communicating with the PCIII
    Sep 2004
    RZ250-R
    117 times
    Quote Originally Posted by reddog View Post
    http://www.powercommander.com/downlo.../Page12.13.pdf
    yeah looks like it
    also make sure your version of the windows interface is up to date too
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    112 times
    10 Post(s)
    for a re-flsah i think i would have disconnected it and connected it to the 9v battery.
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    G'day Glen
    I downloaded the latest version of the PCIII USB Control Centre Software from their site and installed it. Before I tried to flash it, I was able to check what version of the firmware it was running with the Control Centre, so I know at that point it was communicating.
    I've also read the Manual and it does say you can also supply power to the PCIII by turning the bike on.
    I don't think I got the 9V battery adaptor with my unit when I bought it (2nd hand).
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Hopefully I haven't f&%cked the unit up?
    Sep 2004
    RZ250-R
    117 times
    is this what you need?
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    I think it is yes
    Sep 2004
    RZ250-R
    117 times
    ok...
    so that means i have something you want... ;-)
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    lol
    Would I be able to borrow it for a few minutes to see if solves my problem? I'd pay for it or rent it for the period hehe
    I'm hoping that's all it is and that I haven't fried my unit :/
    Sep 2004
    RZ250-R
    117 times
    oh i have money already
    can i use your bike to do a circle burnout?
    tonka128 likes this.
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    If it ends up running, sure why not lol
    Sep 2004
    RZ250-R
    117 times
    SWEET!
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    You break it you bought it though lol
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Olympic rings would be impressive haha
