Results 1 to 10 of 10
Thread: Replacing fork oil with heavier stuff?
    Member Dragunov-21's Avatar
    May 2009
    I live in Tanzania, shit is different.
    CBF-250
    5 times
    My front forks are softer than I'd like - diving under braking etc...
    Is it possible to firm them up a little by replacing the fork oil with a different grade? Is it difficult? What effect would it have on the bike's handling? (Obviously if it'll adversely affect it, I don't want to do it).
    Cheers - Alex
    Quote Originally Posted by barfridge View Post
    good point, but hoping for a pagsta fan is asking too much
    Quote Originally Posted by Amac View Post
    ferris i hope a snake bites you on the testicle.
    Member Chewie's Avatar
    Sep 2007
    All over the shop
    Yamaha R1
    14 times
    How long has it been since you changed your fork oil? Your forks may just need to be serviced rather than changing oil.
    Changing fork oil is a fairly easy job.
    Member Cbr1k's Avatar
    Jan 2004
    Your momma's house
    CB1300 & CBR1000F
    17 times
    Fork oil only last a few years at most so always a good idea to change it.
    However if you are too heavy for the current springs then changing the fork viscosity is a bad way to fix it.
    Quote Originally Posted by Barfridge View Post
    Please don't tell me you expect an internet argument to end up with somebody changing their mind and admitting the other person is right? That has never happened, not even once.
    Member Ryder's Avatar
    Nov 2004
    NSW for now
    2004 R6
    Have used thicker fork oil in my old CB250 and ZZR250 to great effect. This works a treat in bikes that have no adjusters. Also, if you need to increase your preload (which it sounds like you do if it's diving under brakes), you can do it by adding a couple of thin (1mm ish) spacers on top of the springs just under the caps.
    Appropriately sized washers will do this, or if you're lucky and own a 250 with small forks then you might find a 20c coin is a perfect fit. Again, if your bike has no adjusters then this works an absolute treat.
    R6 Turbo
    http://www.perthstreetbikes.com/foru...project-86823/
    Progressing slowly in a future near you
    May 2009
    CBF-250
    5 times
    Quote Originally Posted by Chewie View Post
    The oil's done 2 years, 9000kms. (Original oil)
    Quote Originally Posted by Cbr1k View Post
    I'm 70kg, so the springs should be about right, yeah?
    Quote Originally Posted by Ryder View Post
    Cheers - might give it a shot.
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    29 times
    you can increase the weight of the fork oil and also decrease the airgap. Don't use thicker than 10 weight, and check the airgap in the manual and reduce it by 10mm, this will act as a proportional spring. make sure your seals are in good condition before you reduce the airgap.
    Member Veefore's Avatar
    Feb 2007
    Joondanna
    ^^^^What Arwon said.
    From my fading memory, and someone please correct me if I'm wrong, increasing the volume of oil, or reducing the air gap increases the rising rate of the fork. The air in the fork acts as a supplemental spring that increases in stiffness as it is compressed, unlike a coil spring which has a linear rate. By reducing the volume you actually bring the increasing rate of the "airspring" into effect earlier in the stroke.
    Aug 2003
    PSB Cafe
    YZFR1
    29 times
    that is correct, it is a good way to avoid bottoming during had braking.
    Member bigmak's Avatar
    Jun 2008
    warwick
    636, cbr 600, kx250
    I changed the fork oil from 10w to 15w in my stunta but that was only because i was unhappy with how bouncy it was mid stoppies and i tried everything else i could think of. If your going to do it, do it properly, take your forks off and apart, make sure you clean the internals properly and take your time with it all. it wouldnt hurt to change seals also. In my experience it didnt make the forks 'dive' any less but slowed the process down, which was perfect for what i wanted.
    Jul 2005
    Perth "north"
    11 times
    These are damper rod forks with very little control you can go way heavier than 10w (sorry Arwon ) I've even mixed up oil for these with a bit of engine oil to get enough damping You can preload with 20c pieces as ryder said and yes reducing the air gap will help heaps mainly over the last 1/3 of travel. What bigmak has suggested is worthwhile if you want to do it properly.
    MM
    Sponsored By: Dynapumps, Loadstar Trailers, Mobile Motorcycle Medic, Hi-Tech Components, Motorsportpics.net
