Results 1 to 14 of 14
Thread: Seized brake piston
    Member gordo7's Avatar
    Dec 2006
    ROCKINGHAM
    HONDA CB 900 HORNET
    Seized brake piston
    Looking for a little help in freeing up a seized brake piston. Have decided to enter my '74 XS 650 in historics racing but right side front brake (twin disc model) has seized solid. Tried the drown in WD40 and the air compressor trick but no good. Next step will be heat application.
    Anybody have any ideas??
    cheers
    Gord.
    GORDZ MOTORCYCLE TRAINING W.A
    0419 338 065
    www.mtwa.com.au
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    33 times
    7 Post(s)
    you cant get it to move at all? even with the calipers off and using the lines/lever?
    Member bertie's Avatar
    Jun 2005
    Perth, NOR
    Cagiva Mito
    brake cleaner and a tooth brush??
    Dec 2006
    ROCKINGHAM
    HONDA CB 900 HORNET
    Quote Originally Posted by semi View Post
    She be rock solid!
    0419 338 065
    www.mtwa.com.au
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    33 times
    7 Post(s)
    Id try heating it then
    Dec 2006
    ROCKINGHAM
    HONDA CB 900 HORNET
    That will be the next trick. The fun we have working on 34 year old bikes!!
    0419 338 065
    www.mtwa.com.au
    Member Nero Diablo's Avatar
    Oct 2004
    Out there
    21 times
    Did you try soaking with penatrene or similar product overnight. The Locktight freeze spray supposedly works pretty good might be worth a go.
    Semi Semi's Avatar
    Freo
    K6 GSXR750
    33 times
    7 Post(s)
    IM assuming you're changing all the seals though, right?
    Rob
    Rob is offline
    PSB Expert Rob's Avatar
    Jul 2003
    Ballina, NSW
    919 500's 250
    3 times
    You can fill it up with water, and then heat with an oxy. As the water expands, the slug should come out with a bang - best to point that into a bucket etc.
    Sleeve will probably be rooted etc
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    117 times
    push it all the way in to break the stiction?
    then pump it out with a working master cylinder? hook it up to the rear master cylinder?
    Jul 2005
    Perth "north"
    19 times
    6 Post(s)
    Pump it up with a high pressure grease gun
    Sponsored By: Dynapumps, Loadstar Trailers, Mobile Motorcycle Medic, Hi-Tech Components, Motorsportpics.net
    Member smokeymatt's Avatar
    Oct 2007
    Beechboro
    GSXR 750. GS1000st
    Clamp it in a vice with pressure on the piston and see if you can squeeze it in a little to free it up. Use metho instead of brake fluid hook it up directly to the mastercylinder and see if you can pump it out. It will move, just needs the right amount of pressure. I have an old master cylinder and half a handle bar screwed to a block of wood which i use for such jobs. PM if you want ot come over and give it a go
    Member MattyA's Avatar
    Jul 2008
    Cuttin Ya Grass With Ma Bike
    FZ6n & '78' TY175 Resto
    7 times
    your on the money here no risk of hurtin yourself.
    screw a grease nipple into the brakeline/banjo fitting an pump it up with grease i have done this many-a-time and hasnt failed my yet
    Member chief wiggum's Avatar
    Sep 2005
    alternating between cowgirl and barfie's windaz
    mine
    89 times
    you need a bigger hammer
