Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By g0zer
Thread: Too much oil
    Member shish's Avatar
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Too much oil
    Just changed the oil in my R1 and was riding and noticed every now and then it would blow white smoke. When I stopped I noticed that the oil level was too high in the window.
    Is too much oil going to cause it to blow white smoke and it is going to cause any damage to my '07 R1?
    Do or do not. There is no try
    Member BigTim's Avatar
    Mar 2006
    Tiller
    10 times
    Yes, and yes.
    Depends on how much extra you've got in there, though. A few hundred mL shouldn't be an issue. An extra litre or more, the crank can be running in the oil, which causes dramas.
    FTP
    T.G
    T.G is offline
    Member T.G's Avatar
    Apr 2008
    Tap-tap-tapping
    4 times
    Might of just blown by the rings and caused minimal damage but you'd have to be lucky
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    So it'd be a good idea to drain the excess oil out?
    Member Kaido's Avatar
    Dec 2007
    51 times
    24 Post(s)
    how much oil did you put in?
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Around 3 and a bit litres. The manual says it will take 3.1 litres with a oil filter change. So if I've gone over it would of only been a little bit over..
    T.G
    T.G is offline
    Member T.G's Avatar
    Apr 2008
    Tap-tap-tapping
    4 times
    Did the smoke go away as you kept riding?
    Jun 2010
    Thornlie Perth
    2007 Yamaha YZF-R1
    Yes. It doesn't do it all the time and when it does it does go away. It's only done it twice and only after a riding for a while and it will stop after a few minutes.
    Member Shady7/8's Avatar
    Oct 2008
    ***CLASSIFIED***
    User is a dirty Perve
    249 times
    Did you change the filter as well?
    If not then your're a few hundred mls over.
    Keep up to date with my Everest Trek here! http://your-everest.com/
    Raising awareness, and donations here - http://www.everydayhero.com.au/youreverest
    Quote Originally Posted by Martin Luther King Jnr
    Member g0zer's Avatar
    Sep 2004
    RZ250-R
    117 times
    Quote Originally Posted by shish View Post
    its nice to be able to see daylight in the sight glass, so you have a visual reference for how much over you are- dont bet your motor on gut feel. the amount of oil hungup in the motor after its been drained is an unknown.
    personally i whack in ~80% of the capacity quickly by volume then spin the motor up for a minute to fill all the galleries filter ect then shutdown let it drain back to sump for 10 minutes before filling the remainder to the sight glass reference.
    edit: also the oil/motor should be cool when you check oil level, hot oil will give a false high reading.
    Deicide likes this.
    Member Lee_nightstar's Avatar
    Oct 2011
    Morley
    08 YAMAHA YZF-R1
    save your self from the dramas and just drain abit out and have it lined up properly! thats what I got told once at yamaha 5star. goodluck anyways
