I have a 90 CBr250rr and cruising up to 120kph is fine not a problem but if i continue to accellerate the front wheel begins to wobble by about 150kph i have to back of cos its vibrating pretty bad.
At first i thought could be shagged head stem bearings but had a look and they appear to be fine, not loose and have nice smooth movement.
Then today i noticed the wobble is actually in the bottom of the forks, the dust seals are pretty knackered and have cracked up a lil bit so they need to be replaced and u can see and feel movement around this area.
Is it fixable? New seals and change oil? or is there more likely to be more terminal damage in there and i'm better of just tryin to find some new forks?
cheers mike
