Now about fuel petcocks. The standard petcock has ON-OFF-RES (RESERVE). OFF is, well, off. ON takes fuel from a tube that sticks up from the petcock body into the tank. When the fuel level goes below the top of the tube, the carb runs out of gas until you turn on the reserve. The RES draws fuel from the bottom of the tank. Both tubes usually have fine wire filter screens on them and another screen in the petcock it's self.
The second type of petcock has a diaphragm that automatically shuts off the gas when the engine stops. You will see a hose going from the petcock to a fitting on the intake manifold of one of the carbs. This supplies vacuum to one side of the diaphragm, opening the fuel valve inside the petcock. These petcocks have three settings. ON-RESERVE-PRI. ON is on. Reserve is reserve and PRI is Prime. Prime bypasses the diaphragm so you can fill the carbs with gas after they have been drained. Set it on PRI, fill the carbs and put it back to ON. Sometimes, ON is called MAIN.
