Results 1 to 12 of 12
Thread: Help! My car got a yellow sticker
    Dec 2005
    Yokine
    20 times
    ... does anyone have a spring vice/clamp?
    And, does anyone know how easy it is to replace them on an 03 Astra?
    Or for the sake of a few buck, paying someone to do it - recommendations?
    Member Cbr1k's Avatar
    Jan 2004
    Your momma's house
    CB1300 & CBR1000F
    17 times
    If I am not mistaken you can get rubbers from shock places that go inbetween the coils. These will give you a bit more preload.
    If you do need to replace the springs you can hire the spring compressors at hire shops for about $10 IIRC.
    But why would you want to make a car that low????
    Quote Originally Posted by Barfridge View Post
    Please don't tell me you expect an internet argument to end up with somebody changing their mind and admitting the other person is right? That has never happened, not even once.
    lee
    lee is offline
    Member lee's Avatar
    pink r1200gs
    9 times
    [/b]
    i think he's saying its already low, and he needs to make it standard ride height before he'll get the yellow removed
    Member Dingo's Avatar
    Mar 2005
    Crumpys Jawa
    Whippersnipper, Superhawk, Mini-Fighter, Bali Harley
    Post
    Would you believe i have a set of spring compressors in my garage?
    I have nothing else , but i have them
    U got my number Rhino?
    Member Barney's Avatar
    Feb 2006
    Doubleview
    if you're gonna do it yourself, be careful.
    When you're compressing and uncompressing the springs work on each spring compressor evenly, i.e. 5 turns on the left, 5 turns on the right, 5 turns on the left etc.
    MUCHO energy stored in the springs when they're compressed, you definately don't want to be anywhere near them if a spring compressor slips off one side!!
    Not a difficult job to do.
    MODERATOR Arwon's Avatar
    Aug 2003
    PSB Cafe
    YZFR1
    29 times
    before you raise it, check your ground clearance , and if your minimum clearance is more than 100 mm, then get a permit for it instead.
    The spring will have to be solid in its mounting when the strut is fully extended though.
    I got a permit for my statesman and it solves alot of issues.
    Member Mirkz's Avatar
    Apr 2006
    Ive heard welshpool and O'Connor pits generally aren't TOO bad.
    Member dr00's Avatar
    Oct 2004
    15 times
    doesnt matter how good the pits are, if you cant get over the 100mm metal/concrete lip on the pit you wont pass but yes welshpool is the go
    Quote Originally Posted by Friedrich Hayek
    "The curious task of economics is to demonstrate to men how little they really know about what they imagine they can design."
    Ok my 2c, when i arrived many moons ago to this fabulous state my Maloo ute was found to be a whopping 23mm too low in the front end. 1 trip to pedders and a new set of springs that raised it 15 mm and a written note to the manager of the rta ;on the road, was much better too as it didnt scrape on Everything just most things. A mate just had his original SLR 5000 torana go over the pits and he had hell drama's with pedantic shit, he reckons freo is the best he went to as they apparently deal with moded, or custom vehicles regularly.
    Sis pacis. Instruo pro bellum.
    Member gsxrando's Avatar
    Dec 2005
    Mandurah Way
    But why would you want to make a car that low???? [/b]
    She wont pass if you try and shim the spring height...... new springs or permit
    Life's a garden... Dig it :-P
    Inactive Member
    Sep 2005
    dig a big hole and bury the <strike>Vauxhall</strike> Holden Vectra. problem solvered.
    Buy a can of degreaser and give it all a good clean underneath, engine bay etc, and if everything is neat and tidy they usually are more leniant on you as they can see you care for and maintain your car, common sense really. Have generally found they will always pick up something minor, just to make you go back and pay a second inspection fee.
    + DOCWA.</span>STRE<span style="color:#008000">AKER
    Dec 2005
    Yokine
    20 times
    Spring issue went in the too hard basket. Got hold of a friend of a friend who owns AutoItalia in Morley, did it for $150.
    Tint was stripped this morning... I&#39;ll remove the sway bar m&#39;self.
    Pits tomorrow morning maybe... I&#39;ll just go to whoever is close. The car is only 3 years old, tidy and I don&#39;t have any concerns...
    Thanks anyways...
    Browney - git fkd
