Results 1 to 9 of 9
Thread: Shaving ones head....
    Member Thomas Crown's Avatar
    Dec 2006
    Mundaring
    195 times
    ... so as something of a simplistic approach, I've taken to shaving my head down to the skin.
    For something that should be simple, it's turning out somewhat complex. Obviously not seeing the back of my noggin is an issue, so from people that do it or have done it on a regular basis, what's the easiest way to maintain a hair-free dome?
    It'd be great if there's some shaped razor / device that can do the job with a minimal of fuss and without me having to call my wife in to finish the job off for me every time.
    Staff Klink's Avatar
    Dec 2003
    PSB Cafe Basement
    S
    18 times
    using clippers or a razor?
    Never razored but with clippers its easy... you just run the clippers a million times across the blind spot in different directions.
    If you can... you MUST!
    Dec 2006
    Mundaring
    195 times
    using clippers or a razor?[/b]
    Razor.
    Got a decent set of clippers and have been keeping it short for a while now, but starting to take it all off instead.
    Inactive Member GORCAT's Avatar
    Aug 2005
    Boganville
    WAX!!!!!!!!!!!!!!!!
    friggin bit on the owww side but the result is awesome...............
    There is no such thing as an accident, people make mistakes............ the trick is to have enough space to make your own, then identify and avoid others making theirs.
    Anyone coming up from behind is either breaking the law............. or enforcing it, the first have to look to rule No. 1, the second have my full attention and courtesy.
    "HORSEPOWER is how fast you hit something"
    "TORQUE is how far you go through it"
    Rule No. 1 : NEVER make contact with a vehicle in front of you, it doesn't matter what they are doing, it is YOUR fault........... geddit!!!!.
    Member thro's Avatar
    Jun 2006
    Ashfield
    CBR600RR7, 1.5x VJ22 RGV250
    7 times
    You just need more blades...
    stuff
    Member Bulbous's Avatar
    Jane Brook
    CBR 954 RR
    mate, you get used to it, i use a Gillette Mach 3 razor, and it takes about three minutes now, doing it about twice a week....... when i first started though, i sliced the back of my head open and it was about 25cm long too....... i held the blade sideways without thinking and then dragged it from the back to the front in one easy movement......... then shoved my head under the boiling water when i realised what i did...... now that is painful!
    use your other hand to scout ahead of the blades to tell you where the hair is left, then follow through with the blades, might have to do it a couple of times in different directions to get it all though..... good luck!
    Dec 2006
    Mundaring
    195 times
    WAX!!!!!!!!!!!!!!!!
    friggin bit on the owww side but the result is awesome...............[/b]
    I seriously thought about that mate. Can you recommend any products for it? A lot of the waxing gear the wife and I have looked and / tried has been pretty damn ordinary.
    You just need more blades...[/b]
    Funny fecker
    Brett is staying with us at the moment. When I walked out of the bathroom he looks at me and says "Can I draw a line down your head? I want to make you look like a giant penis."
    Champagne comedy, etc.
    Member Desmo's Avatar
    199 times
    Obviously not seeing the back of my noggin is an issue[/b]
    the wife[/b]
    Problem solvered?
    Dramallama Taylor's Avatar
    Joondalup
    7 times
    can you hold a mirror in your left hand and use your right for shaving while looking forward into the bathroom mirror?
    This is general advice only and does not take into account your individual objectives, financial situation or needs (your personal circumstances). Before using this advice to decide whether to purchase a product you should consider how appropriate it is in regard to your personal circumstances.
