VESA200 spec. with droppers.
If any one has any suggestions or knows someone please let me know.![]()
Cheers![]()
EDIT: SORTED![]()
Cheers![]()
EDIT: SORTED![]()
Cheers[/b]
What is the weight of the displays?
Whatis the model no of the display? (I know you gave the vesa standard, but some have problems using universal mounts)
How far from the ceiling do you want the centre of the display?
18.5kg
NEC NTL-32XT2
top of display can be 20mm from the ceiling, so i guess a good 300mm to the centre. Will require a drop of 1.8m though as we need to fix to RSJs above the ceiling.
