Results 1 to 2 of 2
Thread: Rear Projection Tele
    Member Ken Oath's Avatar
    Parenthood is my neighbourhood.
    XR 250
    14 times
    We've been given a rear projection TV. Bloody big mother with one slight prob.
    A couple of the colours don't line up. Now I've been through all the manual adjustments possible, and done some research on the net.
    As best as I can make out, one or more of the boards for the adjustment of the guns has probably got a dud joint/solder. BTW, I've even tried manually adjusting the guns, but it all points to a dud joint.
    So in the infinite wisdom of you lot, worth getting it fixed, who will do it. Or should we just return it with a "thanks but no thanks"?
    I've got a sneaking suspicion I know the answer...but no harm in hoping.
    Member Aphex's Avatar
    Nov 2006
    A private road
    One thumps the other screams
    Stop. Leave it alone. Most rearpro CRTs have a manual convergence hiden in the service menu which can then be saved to the auto covergence function if supported. Through moving the guns manually, you're potentially making it hard for yourself to use the convergance fucntion in the system.
    LG by any chance? If so, ive done it many times to my own. I cant imagine the service menus are all that different.
    Quote Originally Posted by IPIT on relationships
