Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Washing Machine Repair
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    17 Post(s)
    Anyone know anything about washing machines ?
    I have a whirlpool top loader that's about 5 years old, it just died during a spin cycle, now if I turn it on it will do the wash cycle and when the dial gets to the spin it will just stop, no noises of any kind.
    As I understand it these are not overly technical bits of machinery, anyone got any ideas as to what the problem may be, where to look or who to call ?
    Thanks.
    Member 19andrew59's Avatar
    Apr 2006
    Kallaroo
    2008 GSX1400
    41 times
    Most likely the lid lock out switch. If it'll do everything but spin, that's my bet from past experience. Either replace it or hook the two wires together to complete the safety circuit (make sure you tape them as they'll be 240V) and away it will go. The spin cycle will now work with the lid up or down, not cat friendly, but I see it as a win/win situation.
    Member Aphex's Avatar
    Nov 2006
    A private road
    One thumps the other screams
    Thats a womans toy. Why are you playing with it?
    Quote Originally Posted by IPIT on relationships
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    17 Post(s)
    Quote Originally Posted by 19andrew59 View Post
    Yea, that is what I was thinking, I know the machine will do a wash cycle with the lid open and the fact that there are no strange noises or attempts to start the spin cycle.
    Ill take a better look at it tonight, probably just replace the switch.
    Quote Originally Posted by Aphex View Post
    I think now that is broken it becomes mine..
    Member Chyna's Avatar
    Aug 2006
    07 R6
    When it's in the middle of a wash cycle, stick your head in.
    That way you'll be able to see what's wrong with it.
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    17 Post(s)
    Why don't you run along and let the adults play with the big scary machinery... *pats head*
    Aug 2006
    07 R6
    Touche... but ever considered it was probably your 'playing' with the big scary machine that broke it in the first place?
    Nov 2006
    A private road
    Bra Wires FTL
    Aug 2006
    07 R6
    Nah, his bras are wireless
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    17 Post(s)
    Looks to be the switch... its O/C with the lid open or closed but if I stuff a screwdriver in there I get continuity.
    Should not be too hard to replace... Though after opening it there is some nasty buildup on the inside of the unit and some rust and shit... I want to get it out to clean it but I can't get the nut off the drive shaft (the one that the agitator goes on) the nut looks somewhat like a pre-load adjuster from a rear shock, I tried one of my c-spanners but cant get it to budge... the drum wont come out without getting that off unfortunately..
    I'll price up a switch and compare that to the cost of a new machine..
    If anyone has some ideas on the nut let me know...
    I was lucky enough to find the service manual
    http://nathanalberti.com/images/6ALBR5233JQO.pdf
    Inactive Member leeham's Avatar
    Nov 2005
    I got a whirlpool
    tilt it over and see if you can see "black rubber stuff" (like rubber from a burnout) on the floor or bits of whiteish ABS plastic broken bits.
    if yes, the cupling between the motor and Gbox is busted, and i dont think it even spins (at All) when this happens or makes any noises (like free spining lecy motor)
    i have a had a few of these parts go over about 10 years of use, it saves the motor and gearbox from going "bang"
    pretty simple to work on imo
    you can get parts at the shop on lichfield st Vic park (just near duncun st) dont know the name sorry
    if it is this buy a spare set, as it most likley will happen again in the next few years
    Become a venture capitalist
    Kiva, loans that save lives
    Nov 2005
    is that nut (part 12) on page 12?
    i also think you have to replace part 22, page 12 when you take it off
    i remember snaping some lugs in it when i replaced parts 8,9,10 on page 12. it seemed i had to to get it out
    after u do it tells us how as i would like to take the bowl out and give it a clean mines a bit grimy looking lol
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    17 Post(s)
    Yea... #12 is the problematic one I think its rusted a little because #24 was missing.
    That shop in Vic Park is just round the corner so should be easy enough.
    I found out the grime is from washing with cold water too often, apparently it has to do with the levels of bleach in some of the bio friendly detergents (esp liquid ones). The recommendation was a maintenance wash one in every 15 with just hot water and powder (vinegar and baking powder were also suggested).
    Member mystery's Avatar
    Aug 2004
    The Pub.
    4 times
    Phipps Electronics in vic park are very good, and from memory a whirlpool warranty repairer, I think thats who Leeham is referring to.
    Apr 2006
    Kallaroo
    2008 GSX1400
    41 times
    Find an Amway person and buy SA8, best powder for washing machines.
    Nov 2005
    yeah but u have to go through the whole "have you thought about your financial future....... would u like to make an income better than u ever thought you could......." speel that amway people try on you
    but yeah i have used that stuff and it really is quite good it used to lift out grease from dead animals , ex butcher quite well.
    Apr 2006
    Kallaroo
    2008 GSX1400
    41 times
    Quote Originally Posted by leeham View Post
    Easy fix, just tell them up front if they pull the whiteboard out and start drawing circles you'll kill them.
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    17 Post(s)
    So... anyone sell amway ?
    I spoke to Phipps, New switch is $57.45 and a new seal is $5.50. I asked here if I needed to replace anything else when taking it apart and she said no.
    She couldn't help me with the nut or its removal tool though
    I'm basically fucked till I can get it off.
    The nut looks like this:
    And I think i need one of these..
    Member Sean'o's Avatar
    Sep 2005
    NoR
    Last time i took a nut like that off a washing machine, it took an hour or two tapping it around with a hammer and brass drift, only to find that it had a couple of little grub screws through the side of it locking it to the thread, have a real careful look for the grub screws, if there are some there, undo those, couple of taps with a hammer and drift and it will come off easy
    Member FireStorm's Avatar
    Jul 2003
    PSB Cafe
    06 CBR1000RR
    7 times
    replace switch and seal.
    dont pull the cunt apart and fuck with it. otherwise things will go very wrong from then on.
    I'm the noob you all pwn!
