| Register | Launch PSB Live! | Chat Room | All Albums | Blogs | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| For Sale / Wanted / Trade Place your For Sale/Wanted /Trade Advertising here |
LinkBack | Thread Tools |
#1 (permalink) |
cb919 cr500 crf$2.50
Any old home brewing gear lying around??
Just need one of these bottle washing bases/stands, and the spring loaded thing that sits on top for pumping solution into the bottles.
The base/stand only needs to be 1 storey high, as long as the washer part fits inside it. Hopefully PSB can turn over some surplus to requirements bottle washing gear ![]() Cheers ![]() ![]()
__________________
PSB Expert, LOLCAT Enthusiast, MotoGP and WSBK Spoiler Nazi ![]() |
#2 (permalink) |
2001 Ducati 748R
I'll help you empty the bottles when they have been sterilised and filled with love.
OK with you?
__________________
#10 (permalink) |
CBR250RR
I soak in a strong solution of washer powder, then run them thru the hottest, longest cycle my dishwasher has. Then i go outside, chop down some trees and laugh at the dying frogs in the gutter.. Stupid Planet.
#11 (permalink) |
1998 RGV250
Rob: I have a bottle tree, but no washer attachment, sorry.
For washing bottles (and just about everything else in the brewery) I used sodium percarbonate, which is the active ingredient in napisan. Get the homebrand one, it has no perfumes and the most active ingredient. Then to sterilise I use orthophosphoric acid, or an iodine solution.
__________________
"Let's think the unthinkable, let's do the undoable, let's prepare to grapple with the ineffable itself, and see if we may not eff it after all."
- Douglas Adams |
#15 (permalink) |
CBR 900RR, ZXR 750
yeah, the outlay is a bit hexxy... but nothing says 'quality' like pulling up at a party, pulling out a keg and a tap.. and pulling a delicious brew straight from your keg..
I've got 9 litre and 18 litre corny's.. wouldnt ever ever ever go back to doing a bloody bottle ever again ! the best thing, buy 3 kegs... go down to 'u brew it' for those of us not so inclined as to do mashes etc anymore - pay them to make.. they wash your kegs, pressure test.. and you just pick it up in a couple days.. cold, bubbly.. drinkable ! and no sediment.. I've done 3 party's now, 50L each - where people have asked " where'd you get those cool little kegs ? ".. and rave about the beer... sure beats the look of repulsion you get when you hand over a " DIY bottle bomb " with 1 cm of sediment in the bottom.. ![]() |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
