Results 1 to 13 of 13
Thread: Winter Mode On Ceiling Fans
    Member Big_Dave's Avatar
    Jan 2009
    Floreat
    11 times
    Cool Winter Mode On Ceiling Fans
    I've recently got a ceiling fan in my bedroom and have once again noticed that ceiling fans have a switch to change the direction of the rotation.
    This new one actually marks it as summer and winter mode.
    "Does anyone or has anyone use fans in this mode during winter ??" , if so what was the experience like ??
    When I get sad, I stop being sad, and be AWESOME instead. True story.
    Quote Originally Posted by lobes89 View Post
    Yea I like the bike but it's hard to get my foot under the brake lever
    Member olyflyer's Avatar
    Feb 2011
    Broome, Western Australia, Australia
    DL1000, 76 CB400 Four
    It is meant to circulate the warm air on the ceiling down when you have heating on, indirectly
    my blog of riding in America, Mexico and Guatemala
    http://damonthenomad.blogspot.com/
    PBF
    PBF is offline
    Member PBF's Avatar
    May 2009
    Busselton
    Red
    76 times
    Yeah whs.
    Lots of heat is wasted up high during winter, so reversing the direction just means you get the hot air from up high, to down low.
    Jan 2009
    Floreat
    11 times
    ahhh, but has anyone tried it
    Feb 2011
    Yes, Works an bit
    Member Thirsty's Avatar
    Jan 2010
    In the Middle
    The Busa's Brother From Another Mother!!!!
    52 times
    7 Post(s)
    Youll find the winter mode makes it go in reverse (duh!!!), as in sucking air up to the ceiling, not sucking it down, bringing the cool air from down low, to flush the warm air as it bounces off the roof and walls down to the lower part of the room.
    Fan forced ovens work why? Cos circulating air makes an more even temperature. More even temparture cooks around the food better, and you actually dont need thermostat as high as a conventional oven (well all conventional ovens these days are pretty much fan forced... My one doesnt have bake on it, just fan grill and fan bake.
    Nanna used to make cakes at xx many degrees on the top shelf, then at another xx of degrees on the lower shelf at different times while baking. Now fan forced has done away with that. Have a look in the frozens section in the supermarket, a lot of packs will have a higher degrees celcius cooking instruction for conventional oven, and a lower temperature, and possibly shorter recommended cook time for fan forced.
    When the only tool you have is a hammer, every thing starts to look like a nail
    Jan 2009
    Floreat
    11 times
    ahhh good answer
    Member chew's Avatar
    Aug 2005
    Rivervale
    147 times
    Use it on low speed to avoid draft induced cooling effect on bare skin.
    Member agrid's Avatar
    Apr 2008
    270 times
    13 Post(s)
    I tried it on mine years ago but the fan spins too fast and the draught makes you feel cold. I put a globe inline to slow the thing down but it was still too fast so we never bothered with it again. We have pretty high ceilings so maybe that's the problem.
    Aug 2005
    Rivervale
    147 times
    A wouldnt think a globe would have much effect. A different controller maybe? Tie a child to the blades? What is your main method of heating the house?
    Apr 2008
    270 times
    13 Post(s)
    It was one of those pilot light globes.
    Aug 2005
    Rivervale
    147 times
    Incandescant? I am not sure how they regulate those ceiling fans, voltage, amps etc. Thats what you would need to know before you could sort it.
    Member Uncle Flash's Avatar
    Nov 2008
    Way Out West
    Awesome Italian Scooter & Awesome Italian Motorcycle & Awesome Italian Bicycle
    17 times
    Make 'em spin backwards and watch all the greasy dust fly across the room!
    You might want to wipe the blades first.
    Please, call me Flash...
