| | | MY 1994 (SS, SL, & SP/CR) | MY 1995 (SS, SL, & SP/CR) | MY 1996 (SS, SL, & SP/CR) | | |
| SS & SL: aluminum-bronze valve guides (marked V1)* | SS & SL: thicker cylinder head studs (8mm) (marked M)* | SS, SL SP/CR: marked V2 | | | SS, SP/CR: bimetallic intake & exhaust valves; modified valve timing
CR: 1998-spec engine with Tecnol/Nikasil cylinders, updated rings, & internal oil return lines; longer engine heatsinks; no CAGIVA-style or TPG-style Ducati castings on engine/cases
| FE: bimetallic intake & exhaust valves; modified valve timing
FE (USA only): engine with Tecnol/Nikasil cylinders, updated rings, & internal oil return lines; longer engine heatsinks; no CAGIVA-style or TPG-style Ducati castings on engine/cases |
Engine (Bottom End & Clutch) | SS & SL: 31/62 straight cut geared primary drive ratio; stronger & additional (2) bolts for flywheel-flange (than MY 1991); updated clutch pack (16 plates)
SS: steel clutch cover
SL: aluminum vented clutch cover
| SS & SL: steel clutch cover | SS, SL, SP: remote clutch reservoir
SS & CR: standard steel clutch cover
SL & SP: carbon fiber clutch cover | | SS, SL, SP/CR: new castings with stronger bolts & additional (1) bolt; no boss for kickstarter; sound absorbing (rubber gasket) steel clutch cover | SS, SP: adjustable clutch lever
SS: steel braided clutch line (not AUS)
SP/CR: rubber clutch line | FE: adjustable clutch lever
FE: steel braided clutch line (not USA & AUS); rubber clutch line (USA & AUS)
FE: carbon fiber clutch cover (not USA); steel clutch cover
(USA only)
FE (USA only): 32/59 drive ratio |
| | | MY 1994 (SS, SL-III, & SP/CR) | MY 1995 (SS, SL-IV, & SP/CR) | MY 1996 (SS, SL-V, & SP/CR) | | |
| SS & SL: oil cooler below horizontal cylinder | SS & SL: updated oil pressure switch | | | | SS & SP: oil cooler above horizontal cylinder
CR: oil cooler below horizontal cylinder
| FE: oil cooler above horizontal cylinder |
| | | | SS, SL, SP: oil temp gauge* | | | FE: carbon fiber dash; no battery warning light
| SS & SL: 300W alternator; Kokusan ignition; Champion RA6YC spark plugs | SS & SL: 350W alternator; Champion RA6HC spark plugs | SS, SL, SP/CR: lubricated alternator cover bearing; thicker alternator cable with PVC; updated Ducati Energia voltage regulator*
| SS, SL, SP/CR: new 350W alternator* | | SS, SP/CR: new Shindengen voltage regulator* (3-phase) | FE (USA only): 520W alternator; new Shindengen voltage regulator (3-phase); starter solenoid reversed for easier access to wires |
| SS & SL: Brembo P4 30/34 brake calipers; Brembo PS15 brake master cylinder
SS: 320mm semi-floating steel rotors (5mm)
SL: 320mm full-floating cast iron rotors (4.5mm) | SS & SL: semi-floating steel rotors; Brembo P4 30/34C brake calipers*; Brembo PS16 brake master cylinder | SS, SL, SP: remote brake reservoir
SS: full-floating steel rotors
SL & SP: full-floating cast iron rotors; thinner (4mm) rotors
CR: semi-floating steel rotors
| | | SS, SP: revised full-floating steel rotors*; thinner (4mm) rotors; updated brake calipers with greater fluid volume*; adjustable brake lever
SS: steel braided brake line (not in AUS)
SP/CR: rubber brake line
| FE: updated brake calipers with greater fluid volume*; full-floating cast iron rotors; adjustable brake lever
FE: steel braided brake line (not USA & AUS); rubber brake line (USA & AUS) |
| SS & SL: Brembo P2 105N caliper; Brembo PS 11 brake master cylinder; 245mm steel rotors | SL: full-floating caliper with rod | SL & SP: full-floating caliper with rod | SS, SL, SP/CR:
revised brake master cylinder, brake lever, & brake reservoir location; brake pads retained by springs
SS & CR: full-floating caliper
| | SS & SP: full-floating caliper with rod
SS: steel braided brake line (not AUS)
SP/CR: rubber brake line | FE: full-floating caliper with rod
| SS & SL: aluminum swingarm | SL: stiffer aluminum swingarm | SS, SL, SP: stiffer aluminum swingarm
CR: steel swingarm
| | | | FE: aluminum swingarm (same as MY 1994 onward) |
| SS & SL: adjustable 41mm Showa GD011 forks with 103mm travel | SS & SL: adjustable 41mm Showa GD011 forks with 120mm travel | SS, SL, SP: adjustable 41mm Showa GD021 forks with 120 mm travel
CR: non-adjustable 41mm Showa forks
| | CR: lower-spec 41mm Marzocchi non-adjustable forks | | FE: adjustable 41mm Showa GD021 forks with 120 mm travel |
| SS & SL: adjustable Showa GD022 shock
| | | | CR: lower-spec Boge shock | | FE: adjustable Showa GD022 shock |
| SS: 3.5 black Brembo rims (red models), or white Brembo rims (black models); 17mm solid axle
SL: 3.5 Marvic 2-piece aluminum and magnesium rims
SL: 3.5 bronze Brembo rims | SS, SL, SP/CR: 3.5 bronze Brembo rims; larger solid axle (20mm) | SS, SL, SP/CR: 3.5 gold Brembo rims | | | FE: 3.5 black Brembo rims |
| SS: 5.5 black Brembo rims (red models) or white Brembo rims (black models); 17mm axle
SL: 5.5 Marvic 2-piece aluminum and magnesium rims
SL: 5.5 bronze Brembo rims | SS, SL, SP: 5.5 bronze Brembo rims
CR: 4.5 bronze Brembo rims | SS, SL, SP: 5.5 gold Brembo rims
CR: 4.5 gold Brembo rims | | | FE: 5.5 black Brembo rims |
| SS & SL: white frame; steering lock (25 degrees)
SS: new frame-seat buffers* | SS & SL: bronze frame | SS, SL, SP/CR: bronze frame; new black side stand. | SS, SL, SP/CR: gold frame; gray side stand
SL: revised solo seating support
| SS, SL, SP/CR: protective washer for lower steering head bearings* | SS, SP/CR: increased steering lock (28 degrees) | FE: increased steering lock (28 degrees); stronger steering head brace; gray side stand |
| SS & SL: silver footpegs | | SS, SL, SP/CR: black footpegs | | | SS, SP/CR: silver footpegs | FE: silver footpegs |
| SS: red with red mirrors (full or half fairings) or black with black mirrors (full fairings only); plastic fenders; solo seat cowling
SL: red with red mirrors (except USA) (full fairings only); yellow with yellow mirrors (USA) (full fairings only); carbon fiber front fender; solo seat
| SS: red with black mirrors only (full or half fairings) | SS & CR: plastic fenders
SL & SP: carbon fiber fenders
SL: red with black mirrors or yellow with black mirrors (full fairings only) | SS, SP/CR: red with black mirrors only (full or half fairings); revised windshield | SS: red with black mirrors or yellow with black mirrors (full or half fairings)
SP/CR: red with black mirrors only (full or half fairings) | SS, SP/CR:
fairings with side vents; revised CAGIVA-style graphics
SP/CR: red with black mirrors or yellow with black mirrors (full or half fairings)
SS: carbon fiber front fender
CR: plastic fenders; solo seat cowling
| FE: carbon fiber fenders; carbon fiber front sprocket cover; fairing with side vents; TPG-style graphics (none on fuel tank and front nose fairing) |
| SS & SL: revised seat supports (than MY 1991)
SL: highmount Termignoni street exhaust; number plate on solo seat; 3- digit plate on triple clamp
| SS & SL: new horn
SL: no SL for USA market; solo seat with 1 on seat number plate | SS, SL, SP/CR: revised seat/helmet lock.
SP: 3-digit plate on triple clamp
| | SL & SP: letter & 2-digit plate on triple clamp | SS, SP/CR: revised seat padding; carburetor heating kit (some models)
| FE: silver with black mirrors (full fairings only) revised exhaust header for better ground clearance; highmount Termignoni street exhaust; revised solo seat padding; carburetor heating kit (some models); side helmet lock; 3-digit plate on triple clamp
