Results 1 to 5 of 5
Thread: DP Rear Stand bearing failure
    Member SVInfinity's Avatar
    Apr 2009
    North of River
    Ducati
    I wash my bike quite regularly and I just checked the rear stand by rotating the pin that goes through the rear wheel only to find the bearing are shot.
    Look like water has got into them as when I removed the circlip to pull the pin out of the stand I found water sitting inside the housing.
    Luckily enough the bearings are quite easy to come by: 6005.2RS,25x47x12mm and I will replaced them with stainless steel sealed ones which should fair better.
    Just thought I would give a heads up to people who wash their bike whilst using one of these stands.
    Apr 2009
    North of River
    Ducati
    Out with the old and in with the new.
    Replaced standard bearing with dust seal for stainless steel sealed bearings
    Knocked out the old bearing with a pin punch
    Like new but better
    10 times
    Wonder how the bearings in the wheel look?...are you using detergents/degreasers to clean??
    Member shan's Avatar
    May 2007
    Above you
    Big bang boom and a sewing machine
    229 times
    15 Post(s)
    MMMm bike porn in the backround
    REPENT MOTHER FUCKER
    TurboR1-
    Say what you want about pedophiles, but at least they slow down around school zones.
    Apr 2009
    North of River
    Ducati
    Rear wheel bearing are fine with no sign of corrosion.
    Using Truck Wash and then an air compressor to blow down bike. No corrosion anywhere on bike. Obviously rear stand was a bit neglected with regards to ensuring it was dry before storing
    Quote Originally Posted by kel999 View Post
