Page 1 of 2 1 2 LastLast
Results 1 to 20 of 38
    Member -JC-'s Avatar
    Apr 2006
    SOR
    06 SXV550, 09 ZS200GY, 09 ATV110, MV 312R F4, 00 SV650 & the Hemi
    MV Agusta losing coolant
    I took the MV for a spin last night and lost all the coolant.
    The bike is new, has less than 300kms on the clock.
    Still running it in, so was taking it very easy, it wasn't too hot, the temp guage didn't go over 100, didn't do too much stop start and every time I stopped it left a puddle of coolant.
    This morning there's no coolant at all in the top bottle.
    I'm just trying to get the lid off the bottle now to refill the coolant before I send take her back and see if it's a warranty item.
    ANyone have similar problems?
    -JC-
    Apr 2006
    SOR
    ok, after removing the fairings topping her up with coolant and running it for a bit it seems that the coolant is escaping through the overflow, couldn't find any leaky hoses.
    Last night I could clearly hear the coolant boiling (bubbling) even though the bike temp wasn't reading over 100...so maybe guessing that they put some cheap arse coolant in with a low boiling temp.
    Has anyone had similar experiences or suggest what coolant or solutions?
    -JC-
    rod
    rod is offline
    Member rod's Avatar
    Melbourne
    Ducati 999R #0069, Italjet D180, ZX9R C2
    You can try changing the coolant for something you know is good and make sure the cooling system is purged of air. On a hot bike like the MV maybe try engine ice or some alchohol based coolant. If the temperature gauge is accurate and you know it's not boiling then there may be a something like a little leak into the jacket from a cylinder. My old Laverda did it after a good run and retorquing the head solved that.
    It's not an uncommon problem with MV's and I think there are a few threads about it on mvaugsta.net.
    Click here to see my Ducati 999R in the PSB garage... You'll love it!
    Member Sventek's Avatar
    Nov 2006
    2007 BMW K1200S
    It's a pretty common problem with MVs. Rod is right about engine ice being found to help. If you have a quick look at mvagusta.net, I'm pretty sure you'll find some good suggestions there.
    "Once you can have people more frightened of disorder than tyranny, it enables you to do almost anything you like so far as legislation is concerned." Chief Judge Antoinette Kennedy, 26/3/2010.
    Member -Stevo-'s Avatar
    Oct 2005
    Shelley
    dodgy radiator cap?
    RT
    RT is offline
    Member RT's Avatar
    Jul 2004
    MV Agusta 312R
    don't stress mate, its just what they do...... i have attached a small can to catch the over flow, stops it spewing all ova the fairings and stops random people telling me my bike is broken lol
    +1 for engine ice, rick gill normally supply it
    also check into getting the upgraded water pump and cover, i have just installed it on mine and seems to make a bit of difference so far
    also don't put too much coolant in, fill it up only to the low level mark
    rod
    rod is offline
    Member rod's Avatar
    Melbourne
    Ha ha, an overflow for the overflow?
    Apr 2006
    SOR
    Thanks for the link, checking out mvagusta.net now.
    I'll try the engine ice although I bought the bike grom Gill's and thought they would have put that in.
    -JC-
    Member Vincenzo's Avatar
    Oct 2005
    F4 312R & GSXR 600 - K7's
    Certainly agree with previous posts - normally relates to the coolant level. I can remember both of Rick Gill's F4 Demos dumping coolant like crazy when I specifically took them out for 'testing' on really hot days & the temp gauge was over 115 degrees C.
    Touch wood, my 312 has been behaving itself in hot weather & have not had any coolant overflow issues.
    What you really have to be concerned about is if you lose all your coolant because of a fatigue fracture of the radiator on the top left side just below the securing bracket. It happened to mine & I had to wait 8 weeks for a replacement radiator from Italy.
    Again the mvagusta.net has a myriad of worthwhile threads about overheating, coolant leaks, overflows & radiator defects - but don't get too depressed, the bike itself is addictive!!
    Avatar: Sunburnt Photography. Signature: Ozboy
    Member dragsta's Avatar
    Jan 2008
    Forrestfield
    suzuki 750
    Your just not riding it FAST enough dude
    I dont think you even had the speedo showing triple digits last night, maybe I could RUN it in for ya
    Member Shadow78's Avatar
    Oct 2008
    ***CLASSIFIED***
    User is a dirty Perve
    Common known thing for a new MV...
    Being new (only 300kms) I wouldn't stress about alternatives just yet... Leave it be for a few more hundred k's then if it's still an issue then look into alternatives... especially if it's not getting hot...
    As for what coolant is in there it should be a AGIP coolant or possiblyMotul Inugel
    ps 110 is still running fine!
    My 08 Brute spat coolant a fair bit during run in then was ridden pretty firmly afterwards and never spat any more...(well til I took her down the road )
    My new 06 Brute having done 4000kms only just spat coolant on me on Sat and has never done before.
    and my 07 Brute only doing 1800kms has never spat coolant on me...
    Member Broms's Avatar
    Jun 2007
    Could be an airlock somewhere JC. There has been a lot of chatter on the MV forum about air getting stuck in the lower radiator.
    The refilling procedure to combat this problem is ridiculous; here is a post from that site after discussion with an MV technician;
    Another overheating cure? - Page 7 - MVAgusta.net
    The MV rep called me this morning re: the filling of the cooling system. He spoke both with people in the US and Italy. I'm impressed with his/MV's caring and interest.
    The cooling system should be refilled per the shop manual which requires both elevating the front end and tipping the bike from side to side to displace trapped air. One person told him that the front end should be raised 1 meter (that's alot) and when tipping the bike two people should do it in order to get maximum lean. That's alot of screwing around in my book but if you want an MV I guess that's one of the prices.
    Venting the top of the lower rad is a good solution I believe, and I'm going to ponder that mod. But it will only eliminate the need for tipping. Still have to raise the front end for the engine passages to bleed.
    One more tid bit. There is a revised resivoir/surge tank cap which does a much better job if controlling internal pressure in the system. It is black with a yellow dot on it. If you don't have the dot (I don't) then get the newer version. Might just be the cause of that cracking at the upper left of the top rad.
    Hope this helps.
    Nothing is easy owning an MV.......other than tearing up money.
    Oct 2005
    It must be an 'Italian' thing, as the Benelli Tornado radiator bleeding procedure required 'gymnastics' too; but one of the more endearing features of the 900 Tre was how cool the bike was compared to the F4's.
    Apr 2006
    SOR
    Quote Originally Posted by Broms View Post
    Mate, that is insain. I'm finding as fantastic as Italian bikes are they lack sanity, the Aprilia also has it's fair share of insanity too.
    Quote Originally Posted by dragsta View Post
    Not sure what your point is mate, you were riding it when it started to gush coolant.
    Topped up the coolant and turned up the pace for a spin, didn't lose a drop of coolant and the temp stayed nice and low.
    Serves me right for trying to run the bike in as per the manual...I should just go back to running it in on a Track day.
    -JC-
    Member Ozboy's Avatar
    Apr 2007
    North of river
    Quote Originally Posted by RT View Post
    ^^ This is all you have to do JC, I've not lost a drop of coolant in the MV.
    Avoid riding in summer, its just aggrevating on the MV, unless of course your going rural riding.
    07 MV F4 1000R
    Member wolfies's Avatar
    Oct 2009
    perth
    mv brutale 910s
    Must be a common problem as mine which is a 08 brutale which only has 300 ks on clock did the same thing tonight which is a cold night, temp gauge around 102 and as I stopped to open the gate noticed collant pooring out of overflow . The top bottle is still half full . Am not going to worry about it yet ,as if it is a warrantee issue or things just bedding in , we will have to wait and see. JC what did you find out.Cheers
    Apr 2006
    SOR
    Quote Originally Posted by wolfies View Post
    Wolfies,
    As others have said it's a common known problem.
    Basically if you're gonna ride slow or through traffic you're gonna squirt coolant. I was running mine in fairly slowly on a cool night and lost a heap of coolant...I overfilled the overflow bottle the next day and went for a 30c day ride at moderate pace and didn't lose a drop of coolant.
    If you're overflow is still 1/2 full you've got nothing to worry about...in fact it's probably still too full.
    There's lots of advice out there and different possible solutions...the severity of this problem will depend on how you want to ride it.
    My plan is to gradually work through this beginning with the first easiest solution (keep the overflow at the minimum level), I'll also ride normally with less focus on the run in proceedure in the manual...if that doesn't work the work through the other options...engine ice, second overflow, larger pump, bottom radiator bleeder, etc if I have to.
    Checkout the MV website there's heaps on there about this.
    This also aligns with the advice from Rick Gill's (where I bought the bike from), they're also happy to check it out if I want to make sure that there's no trapped air.
    -JC-
    Member jules_1972's Avatar
    Land of ATO Tax Offset Applicable
    Ducati 998, XR600, Ducati 999R Track, Ducati 900SS
    What rpm range do you ride in?
    Might sound silly, my old 888 used to run cooler at 100km/hr if I was in 5th
    gear with higher rpm rather than 6th and lower rpm.
    The water pump impeller design was the key to that one.
    Vee2 has done the Impeller mod/Fan mod on his MV F4, this made a very noticeable difference to running temps....
    Ping him.
    RT
    RT is offline
    Member RT's Avatar
    Jul 2004
    MV Agusta 312R
    a little over $300 for the updated water pump from mv, worth the money IMO, bike has been running sweet and i don't stress at every red light now
    Apr 2006
    SOR
    ^^^ I'll probably end up giving that a go, I do like the slow, scenic rides along the coast.
    Jules, the bike is fine at 100...it only heats below that, and yes I was originally keeping the revs down...following the run in instructions in the manual.
    -JC-
Content Relevant URLs by vBSEO 3.5.0 RC3
