Power Commander 5 for 2011 1198
Has anyone installed a PCV on a 2011 1198?
Will the same unit from the 2009/2010 work in the new model?
I'm pretty happy with the DP for termi ECU so not tried it. I'm always worried about screwing with the already rapid and progressive power delivery. Anything in particular you want to improve? If it makes a significant improvement somewhere I might be interested. After seeing a PC III not working on an SXV, I'm a little wary unless convinced they'll do a lot better than stock.
^^^^ I cant be arsed doing it for you,
but maybe do some searching and compare part numbers of the two ECU's if you can find a site that lists them. Otherwise maybe call Justin at Protwin as he has done them.
Had a good experience fitting the PCV to my streetfighter. Cleaned up the bottom end. Protwin reflashed the factory ECU to turn off the O2 sensor which allows the PCV to tune the entire rev range. Can also add a quick shifter for $220.
- You may not post replies
- You may not edit your posts
Forum Rules
Content Relevant URLs by
vBSEO 3.6.0
