when I roll it on its side...
I bought the 748 a few months ago to 'mostly' use at the track.
Anyhow, out there a few weeks ago, first session, about 3rd or 4th lap, flat out going over the top of the hill...
anyone got a spare engine?![]()
eurobrit often have engines going, and good old ebay, sorry its grenaded Monsta :-(
Holy shit!!
Not for individual sale.
oh dear, no wonder she nipped up! lucky to stay upright M. nope you can't have mine.
q
bevel drive, belt drive, desmoquattro, testastretta, desmosedici....a true evolution
-> Triumph 675, a revolution
__________________________________________________ _________________________
I do see something has broken, but please forgive the noobness. what exactly has broken and did it fall inside that 'hole' in the thing that looks like the thing that it broke off?
sorry to hear about it, im just curious to find out![]()
I was going to say it rattles cause its a Ducati, but then the picture paint a disaster tale.
Good luck fixing that.
same boat as ddmore... Is that the conrod snapped?
Duct tape fixes everything
other bits that made it rattle...
the cases are smashed and ground, barrels are fucked!
but at least the heads are ok!
That's an expensive basket case right there.
Drop a line to Vee Two and see what they have stashed around the place?
S.
you say flat out, did it over-rev ?
bloody four valvers eh? thrash the livin daylights out of a two valver with sfa probs and then this..........
q
Give Justin @ Pro Twin a call, he usually has a variety of spares around ... could even make it a 'special' motor for ya.
.. and thats Racer # 193 to y'all; my fabulous sponsors (who all do good shit) are: Graeme Fleming IT Consultants, Vision Image, Pacific Safety Wear, Excess Power Equipment, Pro Photo Booth, Canning Vale Travel, Gryphon Garage Doors
That's a sad story right there. Piston and rod in tiny pieces - you need to find the cause for this calamity. May have lacked clearance between piston and head - may have come loose at the big-end, which causes above-mentioned lack of clearance. Just check piston/head clearance on reassembly - needs around .032" (.8 mm) clearance between the piston and the head's 'squish band'. These clearances are critical, and should be equal between the two heads. 32 thou is a minimum - more is safer, but costs performance...
