Originally Posted by
GD66
You can get tie-downs that secure the front wheel, rather than being tied down by the forks (I think they're called "tyre-downs") : you can make up a spacer to go between the front tyre and the guard beneath the lower fork yoke so you aren't squeezing down too hard against your forks : you could use rope to secure the front wheel up against the bak of your cab, or you could get hold of one of those roll-over-centre front wheel traps to secure the front end and screw it down into your ute....
