91 cbr250rr problem
Hey guys had a look at a cbr250rr today and it won't start just keeps cranking....the owner said she hadn't ridden the bike or started it in a year or so she said it may need some new carbies but she isn't sure so can anyone give me a heads up or help me out before I buy this bike
Chi
Id drain the carbs down and put some new petrol in the tank before anything else? Check the usual stuff - kill switch, sidestand switch?, battery condition etc...
Possible gummed up carbs, which will mean a stripdown & clean, make sure they go back together clean - ultrasonic cleaning will ensure all passages are clear/clearer.
I would say get a plug out and check for a spark but unless you have the arms of a small child / have 6"fingers and two elbows per arm they are a b@stard to get out...
I'm interested in this, my sister has the same problem with hers, i've pulled the plugs and there is spark, i suspect the vacuum line on the fuel tap or something like that is corroded or pinched, haven't had a chance to look at it again.
Sent using tapatalk
Do they have a vacuum-operated fuel supply? Had problems with an NC24 a few years back, the diaphragm was split so wouldnt open?
check to see if spark plugs are getting wet from fuel
if u have a multimeter stick it on the battery and see if it drops below 9volt when u press the starter. if so u need a new battery. if the battery drops a cell it will power the starter motor but then wont have a strong enought spark.
I'll go check the battery when I see the bike again I danno if it's ok for me to start removing spark plugs etc cause I haven't purchased the bike yet
if it hasnt been started in over a year then the battery will definitely be stuffed (unless you have charged it), and the fuel will be stale.
as mentioned, change the fuel first, get a set of jumper leads and get a jump start off a car (make sure it isnt running)
if that doesnt help then check fuel flow and plugs.
steve
- You may not post replies
- You may not edit your posts
Forum Rules
Content Relevant URLs by
vBSEO 3.6.0
