Hi all,
I have two questions.
1. On my battery charger/tender, it says positive to positive, negative to earth (if the batt is in the vehicle), otherwise positive to positive, negative to negative. The reason they given is the presence of hydrogen gas when a battery charges and the possibility of sparking if it's negative to negative. Yet in other instructions I've read, it's just positive to positive, negative to negative. Apart from the hydrogen-spark reasoning, is there any difference? Is one better than the other?
2. After having to bump-start the bike on numerous occasions, I find that the chain sounds 'loose' or just doesn't seem as tight. From those who have experienced this - pushing and trying to bump-start numerous times before the bike actually goes - is that normal?
thanks.
All the batteries I've bought for my Bird have been lead acid, although they are semi sealed so H gas isn't really a problem anyway so works out the same
I can get a gel battery but they are ~40% more $$, I'd rather put a slightly bigger CCA LA one in than a gel for the $$
Alternatively if your like me and paranoid about breaking shit because its the first time you've done it, their's a heap of informative videos on youtube that help, video media is often much easier to comprehend
