Results 1 to 12 of 12
Thread: cbr250rr running sluglike
    May 2008
    Bassendean
    CBR250RR
    Went to leave work today and bike is not revving above 2000
    it went down the road at 5-10klm at full throttle until pulled into a car park and caught train home
    any advice on what I should do would be most appreciative
    It ran fine this morning on way to work
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    19 Post(s)
    Got Fuel ?
    May 2008
    Bassendean
    CBR250RR
    Yes but I think I may have a blocked fuel filter
    heading back now in my cage with some tools and will see if I can nut something out
    Nath's Avatar
    Feb 2004
    PSB Café
    pink r1200gs
    41 times
    19 Post(s)
    Start with basics and go from there.
    May 2008
    Bassendean
    CBR250RR
    Thanks Nath
    got it going again but seems to be fuel blockage somewhere plenty of fuel and tap was turned on.
    tried some F10 fuel cleaner and she started revving normally and just before I got her to a mates place started playing up again, may be a blocked fuel filter. I'll check it out tonight after doing some research.
    Jan 2011
    GPX250
    I had this just recently with my GPX. its was a blockage in the pulse line from the carb to the fuel tap pump (or whatever you call that diaphram valve thingy in the GPX's fuel tap).
    I had recently had the tank off for a couple weeks and i think a spider made his nest inside the hose.
    Steve.
    May 2008
    Bassendean
    CBR250RR
    I was thinking it may be a bug in the system
    May 2008
    Bassendean
    CBR250RR
    replaced spark plugs and found 1 and 4 cylinders not firing
    turned out to be a broken wire from ECU to Coil
    running fantastic once again yah
    Member courtz's Avatar
    Oct 2010
    Byford
    ZX6R
    16 times
    10 Post(s)
    Similar thing happened to me yesterday. Riding on the freeway and lost power all of a sudden. It wouldn't rev very high (don't think I could get it over 6k rpm). Got to an exit, pulled up at the lights and it just died on me and wouldn't start again. Had this problem only 4 weeks ago - carbies were cleaned, fuel mixtures adjusted, air filter and fuel filter checked, new battery, replace old plugs, check spark... What on EARTH could be wrong now? I haven't been able to check it out properly yet, but quite frankly I'm well and truly fed up.
    When you say 1 and 4 cylinders not firing - do you mean there was no spark? Or was there something else wrong?
    I came here to drink milk and kick arse... And I'm all out of milk
    May 2008
    Bassendean
    CBR250RR
    There was spark but would not run
    thought it was coil but that was fine
    bloody broken wire found by Kamal at K-Tec
    if your over it may be worth getting him to check out
    it's a bitch when they play up so I hope it goes well for you soon
    cost me a carton to have someone form PSB road side assist to drop it off to him
    thanks again TurboR1
    Oct 2010
    Byford
    ZX6R
    16 times
    10 Post(s)
    Kamahl was the last person to look at it, 4 weeks ago. He did the retune. I rang him this morning and have plans to drop it in to him again on Monday. I might mention this to him so he can check to see whether it's the same problem you had or not.
    Just getting it to him is a pain - I broke down SoR, live NoR. It's hiding at my sister's place for now. Managed to walk it there from where I broke down.
    This is the last time I'm getting it fixed - if it breaks down again I'm selling it!
    May 2008
    Bassendean
    CBR250RR
    I feel your pain it's a bugger when they play up
    let us know how you get on
