Hi all,
I was riding my bike to uni today and at a set of lights, smelt the strong fumes of fuel. Looked beneath the bike and -- fuel was spewing. Had to shut things off immediately. When I turned it back on to doublecheck, it spewed again. Made a decision to ride home (abt 2km) whilst swearing at my dollars spewing away.
Managed to take a closer look tonight and seems like I've got a fuel hose that needs replacing. As I'm new to bikes and have never done this before, can ya'll check my assumption that it is a new hose I need and what do I need to be aware of?
Have already seen the manual so I'm confident I can lift the tank up. Doubt my hands would be able to fit under to replace the hose otherwise.
Also have a bunch of questions.
- Do I need to remove the tank or just lift it up? It's about 2/5ths full atm.
- Do I need to empty the tank? I don't mind losing a bit of fuel, but I don't want the tank to empty onto me or the floor.
- What type of hose do I need? Do I just go to Supacheap and ask for a fuel hose? Are there thicknesses or ratings I need to know?
- Do I need to disconnect anything else? Manual for removing tank also says to remove vacuum hose. Not sure what that is.
Anyway, good learning opportunity though.
Any other advice much appreciated.
Pics:
Left side of the bike
Ride side showing the fuel hose (is it the fuel hose) going to the whachamacallit
Close-up of where the fuel was spewing from
thanks in advance
only area i can't really check is the lower nozzle at the engine end. it's blocked from sight.
