Results 1 to 12 of 12
Thread: Hyosung GT250r Cutout problem...
    New Member
    Feb 2010
    Queensland
    Hyosung GT250R
    Hi All,
    New to this forum, but thought it would be a good community for advice...
    I have had my Hyo for a few months, without any real problems.
    Lately, I have noticed it has backfired through the carbys on start a few times...
    Yesterday, I was coming home from a mates house, and coming onto the freeway I dropped it back a gear and booted it to redline to merge, then changed to 6th and the motor backfired and cutout altogether for about 3-5 seconds, then came back on after I twisted the throttle off and then back on a bit....
    In the next few minutes of cruising at 7000rmp (100kmh) it did the same thing 2 more times..
    I pulled over, and stopped the bike to look for any obvious problems, but couldn't see anything. I babied it home just taking it easy without incident, but its got me freaked that Its gonna leave me stuck on the side of the road somewhere...
    Anyone got any Idea what this could be?
    Cheers in advance
    Justin
    Apr 2009
    shenton park
    None :(
    clean out carbies????
    Member killswitch54923's Avatar
    Mar 2009
    Butler
    Black 2011 Yamaha R6
    21 times
    bike may be running a little rich if it's constantly backfiring like that, not to sure as to why it is stalling tho.
    Member burlyoaf's Avatar
    Apr 2009
    Woodvale
    96 ZX-7R, ZZR250
    you got 6 gears?
    Member Aussasin's Avatar
    Jan 2010
    On your roof
    2005 YZF-R46 Rossi Edition.
    What year is it? How many K's has it done?
    Member jasle's Avatar
    Feb 2010
    My house in the middle of my street
    Z Thousand
    19 times
    Im going by car (because i play with carbies) it sounds like it is just running to rich not catching a spark... or the spark plug could be iffy just go through the ignition system make sure you are getting the right voltage everywhere
    New Member
    Feb 2010
    Queensland
    Hyosung GT250R
    Its a 2008 model, done about 8000km's.
    Yes, its a 5 speed... sorry.. just used to the 6 in my car... never really counted the gears i guess!
    Thanks for your suggestions... clean out fuel system, check spark and voltages...
    Will post if I find anything suspicious!
    New Member
    Feb 2010
    Queensland
    Hyosung GT250R
    ALso, been reading a bit, and it seems that this bike has a problem with ventilation in the tank... so when you boot it to hard for too long, the suction gets too great on the tank, and effectively stops the fuel flow for a bit... then when you back off the throttle, it allows the air in the tank to equalise, and thats why it cuts back in... sound plausible?
    Someone even said the vacuum was so great, it used to pop part of their tank in, and on release, it would pop back out...
    Any thoughts on this?
    Jan 2010
    On your roof
    Quote Originally Posted by justin777 View Post
    I've heard of this prob before, but never experienced it myself. From what I've read it seemed to be more of a prob with the earlier models.
    Jan 2010
    On your roof
    But still doesn't explain the backfiring through the carbs. Have you rang your dealer about this problem?
    Member Decoy's Avatar
    Jan 2010
    Ballajura
    10 times
    I have a 2008 model and sometimes after a hard squirt on the highway and rolling off and back on again it will lose power (feels like fueling issue) and then surge back on again and go as normal. I guess it's just that tank vacuum thingy
    Once it lost power altogether and I had it towed to the dealership and we thought it was a carby issue. Turns out it was a spark plug lead came loose
    New Member chuppathinggy's Avatar
    Oct 2009
    perth
    Hyosung GT250R
    hey, ive got a 2010 model and had trouble with stalling when changing down gears and revving high up to 3-4 mins of starting the bike. happened about 4 times. when i took it in for a service they said there was something wrong with the throttle computer. not sure of the technical terms... they replaced something in there for 80bucks, but the warranty paid for it. hasnt happened since and ive put another 5000k's on it since then.
